Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
Fabsport CAT bypass install question
Looking at installing the Fabspeed cat bypass on my 2001 996. Is this a DIY? What is involved? I assume PB Blaster will be my friend. Also, I know to protect themselves Fabspeed says the cat bypass systems are only for off road or track. Realistically, I just want a beefier sound and don't do the track. Are these okay for a street car?
1987 Carrera, Guards Red, Black (sold but never forgotten!)
1965 356SC Coupe, Silver on Red
Old 03-21-2019, 07:36 PM
unindicted co-conspirator
looneybin's Avatar
Yes, lots of pb blaster
It’s fairly straightforward, unbolt the cat flange from the header, and the slip connection from the crossover pipe and bolt in the bypass pipe
It will be louder, and likely will set off a check engine light
Do you have emission control where you are?
If so, you will have to reinstall the cats, then do the drive cycle to reset the cat monitors prior to smog check
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 03-22-2019, 01:20 PM
I tried a Cat Delete from Vertex. It is not an X pipe design like the Fabspeed one. With Fabspeed mufflers it was just a bit over the top on the amount of noise on the throttle. I replaced the set with a Fabspeed 200 cell X pipe set and have been really happy with the result.
I had to cold chisel my bolts off. ARP bolts work for replacement. I would recommend new connector clamps if yours have any corrosion or grit in them. My old ones just would not snug down good enough the seal the gas flow.
'99 Guard's Red C4 ; 2005 Cayenne Turbo, 09 Aston Martin V8 Vantage
gone:
W8 SW
couple of Z-3 M's, couple of Lotus, Couple of MG's, Couple of Triumph's
Old 03-22-2019, 06:04 PM
Vendor
Fabspeed Motorsport's Avatar
Location: 155 Commerce Drive | Fort Washington, PA 19034
GSpreeman
Feel free to give me a call to discuss the system.
Hamsa Naser
Hamsa@fabspeed.com
W: +1 267 742 3006
Old 03-28-2019, 06:44 AM
