Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
Porsche Crest Porsche 996 - Ignition key gets stuck and won't turn.
Hello, I am new to the forum, so please forgive me if this question has been asked in the past.
I have a 2000 Porsche 996. It has about 64K miles and is in extremely nice shape.
During the past few weeks, I've been having a problem with the ignition key. When I attempt to start it, the key won't turn. It seems to get stuck and won't move past the OFF position. After a few try's and a slight bit of pressure, it seems to "break free" and the car starts and runs properly. After that, the key will turn as it should, until the next time I try to start it. That said, it doesn't happen every time, so it's kind of intermittent.
Based on the research that I've done here on the forum and on YouTune, it seems that it might be the ignition switch, which is a relatively easy repair.
My question is.... am I diagnosing this properly, or can it be something else based on my description of the problem? Can the ignition switch produce the symptoms or condition that I'm experiencing?
Thank you and I appreciate any help and/or suggestions the group may have.
Best Regards,
Sergio
Old 11-30-2021, 12:58 AM
cdrik915's Avatar
Ignition switch is a common problem on our models ,
Change it , that costs nothing , and you can get this part in a VW store.
It's a bit boring to change , two screws under the dash , but you will be obliged to do some contortions..............
LIGHTER = FASTER !!!
Old 12-01-2021, 08:59 PM
Hello cdrik915, thank you for the advice. I think you're right. Given that its so inexpensive to change, it would benefit the car either way.
I just had the IMS bearing, rear seal, clutch and motor mounts changes, so its not like I am hesitant to spend money on my 996.
I find the 996 to be a great car that has been bad-mouthed terribly. Its actually the best bang for the buck the you can get in a Porsche now a days given the price on some of these cars.
Thank you again and stay well.
Best Regards,
Sergio
Old 12-01-2021, 09:10 PM
cdrik915's Avatar
With pleasure mate .
Do not hesitate , you're right , 996 are nowadays collectors cars , and spending money on it is not loosing money.
And we've just ONE life , take pleasure !!!
A picture of your car would be appreciated please .
Old 12-03-2021, 08:35 AM
Tags
996 , ignition switch
