996 window problem
Hi guys - I wonder if anyone can help me with this problem. I have a 1999 996 with a driver's side window problem. The problem is that with the door closed, if I try to put the window all the way up, it usually doesn't work - gets to the top but then comes back down a bit. The window going up and down also makes a nasty grinding noise, especially near the bottom of the window travel.
I disassembled the door panel and examined the mechanism. Couldn't see anything wrong, but the grinding noise seems to be coming from the motor or the front slider. Any thoughts? Thanks, Dan
1987 911 Cabrio 1989 944S2 race car 1999 996 time trial/street car |
I can't help other than to suggest that you check out the Rennlist 996 forum. It's VERY active and has a lot of people there who are intimately familiar with these cars. They can probably find an answer for you.
sounds like it may be one of two things....but these are just guesses.
1) Window Regulator will usually make a grinding sound when it's going. 2) may be an issue with the door handle? When you lift it, the window comes down about 1/2 inch and then goes back up on it's own automatically and very quickly. Perhaps there is some kind of issue there? Good Luck. J
Jon '85 Targa (recently acquired by Coollx) '02 Carrera 4S (holy moly...I'm in heaven....in the snow too) '06 BMW 325i (gone and forgotten) '03 Honda Odyssey (more dings every day....thanks wifey) |
Re: 996 window problem
