Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
transmission whine
Has anyone expereinced a pretty significant transmission noise from there 996. When I drive my car 50 mph + I hear a transmission whine while I am on the gas. Lifting off the gas the sound goes right away and re-applying throttle it comes right back and it is always present above 50mph.
Anypone experience this and possible have a solution to reduce or diagnose a bigger problem?
thank you
1984 Targa SOLD
996 C4
Dodge Ram
1952 Ford F-1
Old 05-17-2012, 08:04 PM
JFP in PA's Avatar
What gear oil is in it?
Accrochez-vous bien de vos rêves..........."
Old 05-18-2012, 12:19 PM
gearhead
I posted in your cross post...
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 05-18-2012, 12:23 PM
unknown...do you think it is worth using SWEPCO? and is there a way to check the fluid level?
thank you
1984 Targa SOLD
996 C4
Dodge Ram
1952 Ford F-1
Old 05-18-2012, 12:35 PM
gearhead
No, changing to Swepco will do nothing.
http://forums.pelicanparts.com/porsche-911-technical-forum/678550-996-transmission-whine.html
I reiterate, stop driving your car and get it to a professional ASAP!!!
Regards,
Matt Monson
Guard Transmission llc
Guard Transmission |
1974 914 Bumble Bee
2009 Outback XT
Old 05-21-2012, 03:55 PM
Little update, I finally got the car into my mechanic (a dedicated P-car guy) and he is not convinced that it is the pinion bearing. He did notice that the rear tires were 2 sizes too big Ugly situation, they were on the car when I bought it from the dealer and he stated that that may have caused some tranny damage.
We are swapping out the tires and I am keeping my fingers crossed that maybe that is all that was needed?
thanks for the submissions
1984 Targa SOLD
996 C4
Dodge Ram
1952 Ford F-1
Old 05-30-2012, 11:10 AM
The tire size would only hurt the trans if the RR and LR tires were different sizes. Best way to tell a bad bearing is to take out the drain plug stick your finger in there toward the rear of the car and if you get a bunch (alot) of metal goo from the magnet, there's likely a bad bearing in the trans.
Old 05-30-2012, 10:52 PM
You are describing the exact same symptoms that my '99 exhibited. I had the pinion bearings replaced in the gearbox, and all is good. The only noise I hear now is the wonderful PSE.
Old 06-05-2012, 12:09 PM
If his car is a C4, which his signature indicates, it will if the diameter is different from the front. OP should mount proper size tires & check the magnet & replace the diff fluid with new Porsche oil.
Old 06-05-2012, 02:38 PM
