New to 996 ownership... 4 weeks into it with '04 996 AE. Did my oil change a few weeks ago and am waiting for the results of the oil analysis that I did my mail order. Since I have no significant paper work on maintenance, I have no records of any prior IMS replacement or clutch/RMS changes. The area of the RMS is not seeping at this time.
I opened up the old oil filter and inspected it carefully with shop light and magnet. I could not find any metal shaving at all. The oil age is unknown but there was a windshield sticker from a Porsche Specialist from where the car came from (SC) and that would put the age and mileage of the oil about 5 months and 5k. What I did find throughout the filter were small plastic bits that looked like melted wax... very small and rounded... stick to the filter paper surface. You can see them pictured below. Besides what you see, there may have been 2 or 3 more at that size and possible some smaller that I could not collect or see. Research indicates this is probably from the timing chain runners and that they are starting to deteriorate. This is my first oil change with the car and I am planning on doing another when I put about 2k miles on it myself and will hopefully not find any more. Question: does anyone have any experience or knowledge about these ramps failing and how quickly the will go? Based on the amount of plastic I found after 5k miles, is this considered enough to cause alarm or just something to monitor and start saving for the repair in the next 5-10k? This is my daily driver so I am going through it and doing as much preventative work myself as I can in order to have minimal downtime. Thank you. Appreciate your opinions and shared knowledge
04 996 AE (daily driver) 08 A3 Quattro 05 E500 Wagon PO: 11 Raptor SCREW, 11 GTI 6sp mt, 01 Audi S4 Avanti, 95 Volvo 855 T5R, 82 911SC |
No opinions on the small plastic bits in the oil filter? I looked for the cam chain rams that they don't appear to be black in color... at least, not the replacement parts. Anyone know what other internal engine part might produce these small plastic bits in the oil filter? Thanks in advance.
They can be black and brown. Your plan for a short oil change is a good one. You may just want to change the filter at 2k and have a look then finish the 5k miles and drop the oil pan and have a look. I would not worry about the bits for now.
If there are no more or not an increase in quantity I would not worry about that small amount of bits. I agree with just change the filter at 2k to get a read on it.
2013 991.1 Carrera S Cab 2004 996 Turbo CAB X50 sold 2003 996 cab 6 speed Sold 1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold DE instructor since 1985 |
If you want a lot more discussion on this post that pic on
996 Forum - Rennlist Discussion Forums Probably good for 2 pages of discussion with everything from "OMG IT'S GONNA BLOW" to "Mine has been doing that for the last 100k miles."
Chain ramp guides are black plastic and will wear, tensioners are red plastic and will wear. Metal would be much more concerning. Keeping an eye on it is a great idea. Filters are easy to change and uses minimal oil.
