Installing SRP Front Anti-Roll bar
Does anyone have any suggestions for aligning the bearing mounts for the "through the body" front anti-roll bar? I've drilled the holes and mounted the bearings. The problems occur when aligning them. The bar binds when I begin tightening the nuts that support the mount.
SRP suggests that when this occurs, use the anti-roll bar to manupilate the sheet metal until the bar moves freely. It is a cumbersome process. Lots of trial and error. Does anyone have any experience with installing and aligning these bearing mounts? Any experience/guidance will be appreicated! Merry Christmas!!!!! |
lots of trial and error, that is how I did it,
is your gas tank out? that can help you see what is going on, I tightened up the mounts on both sides, and fed the bar in one side and wiggled and bent until it went into the hole on the other side then switch sides and did it the other way Jim
Jim Hamilton If everything seems under control, your not going fast enough. |
Formerly bb80sc
I hope to add this same bar very soon. Any need to reinforce the holes? I have a fairly stiff suspension already, so hopefully, there will not be much movement
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited |
I'm pretty sure you will want to reinforce the holes; I just had to reinforce mine a few weeks ago after they tore.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Super Moderator
The SRP bars are pretty thick, I would definitely consider reinforcing them... It's not really the movement, its the vertical force from twisting the bar. The more stiff, the more stress....
Once you get them lined up, you can either bolt or weld a steel plate around the whole. 1/8"-1/16" is more than enough.
PRO Motorsports
I use the bar to manipulate it like they suggest, and then line up the left and right holes by sight. You can see the other opposite hole, since there will be daylight shining through it. Then with it visually centered, make sure that the hole on your side is straight in line with it. This is with the mounts both fully tightened.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
