Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
BT911's Avatar
Plastic window pull straps
Does anybody know where i can find pull straps for my plastic windows. I'm removing the window regulators and i need something to keep the window closed. I've seen pictures of these straps but can't seem to find them. Any ideas? Thanks.
Old 03-31-2010, 10:23 AM
subscribed.
Old 04-01-2010, 07:21 PM
Administrator
Jack Olsen's Avatar
My advice would be to not throw away your regulators. If it's a street-driven car, the sliding plastic windows get old fast -- at least they did for me. I went back to glass on the sides and front.
Old 04-01-2010, 08:56 PM
Evan Fullerton's Avatar
+1. If only my composite doors allowed for it.
Old 04-02-2010, 12:35 AM
cameron.arnott's Avatar
I used some nylon webbing from my local hardware store.
Looped around the bottom of the window and secured with a small nut & bolt.
Cheers
'74 RS 3.0 Replica
Porsche 968 Clubsport SOLD
'70 911E Bahia Red SOLD
'71 911 S/T Replica 2.3 Twin plug BEAST SOLD
Old 04-03-2010, 12:31 AM
gestalt1's Avatar
try using a leather belt - just cut off the buckle.
BMW 128i
73 rsr clone - sold
68 912 project to become 911r (almost done!)
Old 04-03-2010, 06:10 AM
CRNT918's Avatar
GT-Racing has them, look in the 911R section.
PCA-Chicago Region-DE Tech Coordinator-Retired
PCA-Chicago Region GingerMan DE Co-Chair-Retired
1987 Cab-under construction-Sold pending pickup
1986 911- Race/DE car-Sold
Old 04-04-2010, 04:13 AM
Az 944 Spec Director
M758's Avatar
I got some nylon from my local ACE hardware and then kit to make grommets.
Works great. Even with the stock glass windows and no regulators. I have a window up position and a window down position for use on track. My glass stays in the car when racing and without a regulator I want to hold up to keep it from boucing around inside the door.
Joe P.
88 944 Turbo S - 100% Stock 84 - 944 Spec #94 Red/White
Arizona Region 944Spec Director
Az 944 Spec Champion 02/03, 2006 - 2nd Az Region 944 Spec 03,04,08,09
4th - 2009 NASA Natls - Fastest 944 spec lap at Miller Natls - 2.19.282 (Sat Warm-up)
Old 04-05-2010, 08:29 AM
Super Moderator
cstreit's Avatar
Windex!!!
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 04-05-2010, 08:39 AM
Jack,
Did they get old because it took more effort to raise and lower them? Were they noisy? Lack of adjustability? Other?
Old 04-05-2010, 11:07 AM
BT911's Avatar
Thanks for the info guys.
Old 04-05-2010, 03:57 PM
M758's Avatar
Originally Posted by cstreit View Post
Windex!!!
I don't need windex... That goo is from old window tint I removed. However it left a mess of goo all over the inside of the glass. Never bothered to clean it as when I drive the car the window goes down. So visibility is a non-issue, but keeping the glass in so I can seal it to minimize weather is perfect.
Joe P.
Old 04-06-2010, 06:57 AM
Administrator
Jack Olsen's Avatar
Originally Posted by JP911 View Post
Jack,
I drive a lot on the street -- they would bind moving up and down (like going into and out of parking structures). At speed, they fluttered. Mine might have been lousy pieces of plastic, or might not have been as well-installed as some. I don't know for sure. But I got rid of them pretty quickly. I've still got Lexan in the front quarter windows and rear window. (Maybe rear quarters, too -- I'd have to go out and look.)
But not for the roll-ups.
Old 04-07-2010, 10:43 PM
I would rather be driving
jpnovak's Avatar
I had the same issues as jack. I actually installed the Polycarbonate in the window regulator and tried this. Same issue with the plastic binding in the window frame. I now have glass for the roll-up section.
Old 04-08-2010, 09:53 AM
M758's Avatar
Sounds like you guys were using flat plastic for doors instead of curved glass. That flat trying to fit in curve frame rail was the source of binding.
Joe P.
Old 04-08-2010, 01:11 PM
quick mock up
strap needs to be longer, but you get the idea
"when the power came on, you needed to hold on!" (Juergen Barth)
Old 04-08-2010, 09:03 PM
Todd Simpson's Avatar
I used leather straps for a while, with glass windows. The attachment points were snaps from the local upholstery store.
It looked very cool, vintage and racy. But...the glass window would slide down just a tad and there'd be an annoying leak at the top when I drove on the street.
I put the stock regulators back in. They weigh next to nothing and they do exactly what you need them to do.
Old 04-10-2010, 05:52 AM
Tar356's Avatar
Kundensport has the right idea....
One suggestion:
Instead of using rivets to fasten the strap, use a second strip of aluminum to "pinch/clamp" the strap with(putting a fastener on either side of the leather, not through it). This way, when the leather/holes stretch, you can loosen the clamp, readjust the strap and tighten.
Works great.
Todd Rudaitis
Rennprojekt
Old 04-12-2010, 04:35 PM
BT911's Avatar
kundensport, i saw in your picture that you are using a rear lid pull handle for your door release. Did you modify the cable or did you make a rod to open the door? Thanks
Old 04-14-2010, 09:05 AM
