Lexan - Polycarbonate Rear Targa Glass?
I'm wondering if any of you track guys have seen or heard of anyone replacing the 36 lb rear 911 Targa glass with a lighter weight version made of 3/16" mar resistant polycarbonate (Lexan).
I have found a Porsche 944 example and several Corvette examples, but no Porsche 911 Targa examples. http://emracingcorp.com/scripts/prodView.asp?idproduct=905 ![]() 2008 Z06 Corvette Frame Mounted Wing and Lexan Rear Window - Excelsior Motorsports ![]() Post by sc racing lexan windshields - DragStuff Quote:
https://www.pinterest.com/pin/414049759462676541/ ![]() Quote:
This is the tread which got me thinking about it: http://forums.pelicanparts.com/porsche-911-technical-forum/491200-budget-targa-top-super-lite.html Curious as to what the weight savings would be.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
I am no expert but I did do some internet research. The best way is to have a huge oven that would heat the plexi in and a form ready to slump it onto. I am assuming that is out of the question?
They really aren't hard or complex bends, but they are large bends. You can do it, but not easy and or not cheap, if I was doing this I would make a wooden buck using my original glass as a template. Then I would clamp down the center and use heat guns and work my way out to the edges. The problem is heating the large surface area and clamping, bending etc. when you only have two hands. You'll need helpers. Another option would to use your original window placing it upside down and bend it cold to clamp the center and then using heat and gravity to slump the plexi glass into the original window, but I think it would be risky to your original glass. Perhaps you could build a support for the original glass.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Do you remember this thread?
http://forums.pelicanparts.com/off-topic-discussions/183383-diy-forming-lexan-canopies.html
On one website they provide the math on thickness and cold bends. The thinner, the more you can bend it. Not sure if it was for polycarbonate or acrylic though, will have to Google it again, too many bookmarks at this point. I bet 1/8" would cold bend, but you would need support spars to keep it from blowing out at speed. I think snbush67 is correct about needing to apply heat, but the vette guy said he did his cold, so I'm fairly confused at this point. I've used either 1/4" or 3/16" smoked acrylic on my hovercraft, the windscreen bend I played with was 18"-20" radius and that seemed to max it out without stressing it too much. The Targa glass is nearly 90 degrees at the hoop, similar to the vette though. I just don't understand why I can find dozens of pictures of rear plastic windows on 911 coupes, and not a single Targa. The Cabriolets and Targas can be found with fiberglass hard shell caps, that seems to have filled the track market.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 01-29-2016 at 06:49 AM.. |
To be clear I was asking about air-cooled era targa tops.
However, I did find this one for the 996, Makrolon is a trademark name of Polycarbonate. Classic Hardtop CT 996-001 Quote:
![]() ![]() Other products: http://www.gtn-automotive.com/gtn/sites/gts_e.html Quote:
Polycarbonate = Makrolon Préparation: Allègement Porsche 924... ![]() Quote:
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 01-29-2016 at 08:49 AM.. |
It's a 914 ...
I would think cold bending 1/8" lexan would be tricky. As you probably know, the stuff is pretty strong and doesn't like to do sharp bends. It might be hard to keep it in place when mounted on the car. Not many people race targas, and those who do often just remove the rear glass and run it as an open car with a low front windscreen. This may explain why you can't find any vendors selling targa lexan "glass." Maybe call Shields and some of the other Lexan windshield vendors and see if they'd be willing to do one for you? Maybe they've actually done them and just don't advertise it due to the limited market?
Scott |
Thank you for the input stownsen914.
There are plenty for the 944. Not sure if you could reshape one of these?
The red 944 with the louvres is photo shopped.
Patrick Youtube 333pg333 86 modified 951 |
likes to left foot brake.
This place does nice work but not cheap.
Around $400+ for a rear window. SHIELDS Premier Windshields - Racing Windshield Pricing and Models I used flat material and did it for closer to $150. On both my Camaros we cold bent and attached the plexi to a frame. My source for plastic in San Diego. Custom Plastic Solutions for Over 100 Years | ePlastics® This place I used said that when they make a buck and try to heat form the material it can take 3 or 4 tries to get a good piece. ![]()
From the extra spars and the fact you were able to cold bend it, I'm assuming you used the thinner thickness 1/8" polycarbonate, right? Would you even dare try your radius of cold bend in the 3/16" thickness? A friend of mine owns a plastics shop and does lots of fabrication. I owe him lunch anyway, need to talk to him this summer about this. One of the motivations I'm having is surface rust near the rear glass rubber seal (small spot on drivers side), and the rubber seal looking tired. They say if you can see any surface rust it's actually much worse under the seals than you think. Fixing rust seems like a good idea, even if you cannot currently see it. If I'm going to take the glass and seals out prior to painting (old paint too), then I might as well save some weight in the process. It is a slow process, but I'm in no hurry.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 02-06-2016 at 12:20 PM.. |
The older Camaro has a flimsy hinged rear window like a 944. Since the flat poly piece wants to flaten out we added a dzus fastener on each side to keep it tucked in. I would not want to use 3/16 on this set up. ![]() The newer Camaro has 1/8 polycarobonate as well. But that window in fixed where the entire rear body section is removed with the rear window. The 1/8 thick worked perfect with no side stiffeners needed. I suppose on this fixed rear window you could try 3/16 but the 1/8 does a fine job in the back. We used 1/4 polycarbonate for the windshield. |
Midwest Eurosport had one made for a customers SPEC 911.
They used the factory targa glass to have one made. I believe it was Five Star who made it. Eurosport - The Midwest's Largest Porsche Specialty Repair Shop Brian Weathered is the owner and can point you in the right direction. He said they( Five Star?) made a mold, so it should be straight forward to get one made. I was just racing against this car at Sebring, so I know it exists...
Doug Crossman #92 1992 964 PCA G class #902 1979 911 PCA 911 Cup 96 993 Targa |
Thanks, I will look into this when I get more serious.
Many things on my to-do list first.
From the classifieds:
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/904641-1981-porsche-sc-targa-parts-more.html Quote:
heat bending acrylic or polycarbonate isn't as hard as it seems. You can generate enough heat with a bank of heat lamps or infra red elements like the ones used at auto body shops to cure paint. There are a number of ways to make a quick buck to drape the plastic over.
Even a couple of these would do the trick, then when you're done bending you can heat your patio with it: Heaters | Patio | Solaira Infrared Heaters - GlobalIndustrial.com
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
I realize this is an old thread, but did some of you guys actually fabricate a rear lexan window? And if so: how did you do it?
Under the radar
Heat forming acrylic will need about 275 degs to get it pliable. Polycarbinate, on the other hand needs about 375 degrees. Polycarbinate will cold bend to a certain degree, it will not crack easily or shatter. Acrylic is much more brittle and can crack or shatter if bent cold. Problem with trying to cold form the rear targa window form polycarbinate is you will have to screw it down securly to hold it in place. The other issue is the rear targa window has a slight compound curve which will not be replicated with a cold bend. For a race car or hot rod I would just get some polycarbinate sheet 3/16" thick and screw it in place. If you want to pass it off as OE, it could get expensive.
Thanks. I'm trying to build a 2000lb targa hot rod. I think I'll try a combination of screw and heat bend along. We'll see how it goes.
Reviving this to see if anyone has an update.
1980 911SC Targa 3.6L |
hardly an update, but I have a 5mm polycarbonate plate ready for my rear targa window. Hope to pull the window this week. The plan is to cold bend and screw in place. We will se if I'll need to heat bend as well - if that is even possible.
