Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
Rennsport Doppelkabine -67 project.
Hi, I'm in the process of putting 2,0L 911T engine in a VW splitty bus.
I have some Q's about the oil tank.
1. Is there something to take into concideration regarding the location of the oiltank in proportions to the engine heightwise?
2. What size should the oil tank be?
3. What connections and oil lines do I need to make on it?
Any info is welcome, also things I have not asked.
Thanks you!!
Last edited by Hebster52; 02-08-2008 at 02:41 PM.. Reason: Changed title to suit my own "OT" posting.. :)
Old 02-03-2008, 08:35 AM
553 views in one day and not one have any info?
Old 02-05-2008, 12:29 AM
Hi,
The 2.0 T engine is very rarely chosen for VW conversion.
I am in the middle of installing a 3.2 engine in a 1985 vw T3.
The better choice is to buy a used oil tank from a 2.4 / 2.7 (very easily come by).
You have three lines to use : oil input line,oil output line,engine case breather hose.
I do have a 1955 samba 23 window resto project and I just check with a 3.3 TBO oil tank.
If you like to cut some of the rear hand fender well it fits in almost identical position as the 911.
Good luck
Old 02-07-2008, 10:58 AM
Ok, thanks for the input. The reason for the 2,0l choice is the Finnish regulations. Maximum engine displacement increase etc...
I located an oiltank for 65-71 for 50€ so I guess it will even be correct for the engine.
Old 02-07-2008, 01:48 PM
The 65-71 is the correct oil tank for your engine and increasingly hard to found.The price is a bargain with no doubts!
Good luck!
Old 02-08-2008, 06:17 AM
Greyn57's Avatar
Hi Hebster, the oil tank set up in my Karman has a custom made front mounted tank. Wouldnt work in a splitty set up. The info from Jim Hunter is exactly what I would use in your set up. Standard 911 70 thru to 77 oil is the go. Can we see some build pics ???
64 T34 Karmann Ghia with 2.4MFI flat 6 power. "woo hoo"
Old 02-08-2008, 02:10 PM
You asked for it Dean...
Here's how I found it..
Here at home together with my kids "KidVRod" Gokart.
Pulled the original engine and transmission before I started IRS converting.
Used 944 trailingarms etc.
http://www.fvwa.sitefactory.fi/data/3226.JPG
http://www.fvwa.sitefactory.fi/data/3274.JPG
http://www.fvwa.sitefactory.fi/data/3276.JPG
http://www.fvwa.sitefactory.fi/data/3275.JPG
http://www.fvwa.sitefactory.fi/data/3272.JPG
Testfitted rearbrakes:
Disassembled the frontspindles so I could flip them for a 3½ inch drop.
http://www.fvwa.sitefactory.fi/data/3389.JPG
Testfitted the engine (well engineblock and fanhousing) so see what would need to be modified to make it fit behind the enginelid without cutting a hole in it...
I decided to move the whole engine and transmission package forward about one inch so the fan would clear the enginelid by an inch and a half..
Oh, yes. The transmission is from a 1303S superbeetle.
Thought long and hard on how I would make the front transmission mount when I had to move it forward. I ended up cutting off the original front mount and bought a 901 frontmount that I modified like this:
Last week I started cutting up the enginebay and prepare some pieces to box the rear frame so it would be strong enough for the rear enginemounts for the boxer six.
http://s45.photobucket.com/albums/f98/Hebster52/Rennsport%20Doppel/?action=view&current=DSC_1644s.jpg
Yesterday I finally got the front 944 hubs mounted so I could test the front wheels too with the dropped spindles.
This is now how far I'm at the moment.
Old 02-08-2008, 02:37 PM
Greyn57's Avatar
Nice one Kristian. The Double Cab is the ultimate Splitty in my opinion and having a nice 2ltr flat 6 in the rear will make it even cooler. Nice work. Looks in real good shape too. Gates look to be rust free. Are you going to use a middle mount also??
Old 02-08-2008, 03:02 PM
Thanks. The gates do need some work as the bottom squareboxing on them is pretty badly pitted and even worse repaired years ago... They are also slightly bent as this have been a hard working vehicle...
Not sure if I can use the stock midmount as the headers will probably hit the transmission mounts..
Old 02-09-2008, 02:50 AM
Hebster I have the inner fender piece that the oil tank mounts to. I cut it out of a '69 911
Old 02-12-2008, 05:29 PM
Old 02-12-2008, 05:31 PM
gumba's Avatar
This is a shot of my '68 crewcab w/3.2 & 5 sp. We cut the right inner fender of a 911 and grafted it in for the oil tank. I also cut the back arced section out of a 911. That way I could use the stock engine seals all the way around.
Old 03-09-2008, 10:07 PM
Thanks but I will fab my own mounts for the oiltank. Just as easy.
Also the rear engine mount and seals will have to be custom made as the Splitty Crewcab enginebay is 8 cm shorter than the Baywindow enginebay...
Old 03-10-2008, 10:44 AM
What hardware is used in the stock supportframe to rubber mounts?
Here's the new custom made engine supportframe in the making:
Old 03-12-2008, 04:48 AM
Look! I've now got a late beetle flywheel!!!
or..
Wait a minute!! What is that!!
Way too long since I was able to work on the Crewie now.. Still 2 more weeks before I get more freetime again and can focus on it more...
Recieved the custom made beetle flywheel today though!! 8) Final weight appr. 6.5kg. Could it be even lighter?
Old 04-16-2008, 01:48 PM
I think the original porsche-6 2.0 ltr flywheel would have fitted the type 1 tranny also At least that's how it looks from the one I have.
Did you loose yours or was it not with the engine?
Old 05-01-2008, 10:06 AM
Did not come any flywheel with the engine. I was also told that they would work.
Wasn't ready to pay over 500 Euros for just the flywheel though...
Old 05-01-2008, 10:30 AM
Ok, pity, as you could have gotten mine for less than half of that...
Oh well, the new one looks awesome too!
Great project and great looking crewcab BTW.
Old 05-01-2008, 10:51 AM
Ok. Might concider your offer anyways just in case.
Keep me posted about it.
If possible could you you mail me some pictures of it?
E-mail address is : kristian.ekstrand(at)mirka.com
Old 05-01-2008, 12:10 PM
Thank you Beetspeed for the deal with the flywheel!
Some progress.
Saturday's work:
Yesterday's work: (sorry, mobilephone photo's...)
Old 05-19-2008, 11:50 PM
