914-6 with 911S 2.2 engine - Value?
Hi,
I'm considering the purchase of an original 1971 914-6 that has had it's original engine replaced by a 911S 2.2 engine (also from '71), with Weber 40 IDAs. I have no idea what a reasonable value could be. I know pictures would make a huge difference, but I can't post any right now. The car has steel flares and comes with a set of 7" Fuchs wheels. Needs new tires. It needs to be totally stripped and painted (windows out), but I find it safe to assume there is no rust under the current paint. The engine is in good shape, maybe it needs to be re-sealed. The seller provides a new set of (plastic) bumpers Interior is shot, needs everything new (steering wheel is OK, instruments are OK) Removable roof needs to be re-surfaced (it is pained black. Maybe a replacement is needed) Needs new shocks and probably some suspension rubber. Brakes, steering and tranny (a 901) are fine. Exhaust is fine Needs new rear lights and front turn signals Rest of the electrical is OK Glass is OK Given the flares I'd like to do a GT type of car. Any ideas on what a reasonable price could be? Thanks
Henry 1965 356 SC 1968 911S 1979 930 |
914 Geek
Your rust assumption is unwarranted. These cars love to rust in places that aren't apparent from the outside. Digging into the areas where the right-rear trailing arm mounts, and the area under the battery, and the area around the jack points (under the black cover) can show problems that you won't see just looking at the car.
Does the car have a VIN that starts "914"? If it starts "47", it's been converted from a four-cylinder car. Factory Sixes have a "914" VIN. The lack of originality and the condition bring the value down very much from the top dollar cars. I haven't been keeping up on the value of project cars, so any value estimate I can give would be a total guess. My guess is $10K-$25K depending on actual condition. Maybe more if it's driveable and there isn't any hidden rust. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
gearhead
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Home of the Whopper
About two years ago, I sold a very well running 2.2S engine for $10k.
No induction or engine tin was included.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
This is an actual sixer 9141430xxx. No doubts there
I drove the car yesterday for about 30 minutes, no issues there, the car drives well. The car had a bare metal (windows out) paint job about 10 years ago in white, but it has a few dings here and there, and I don't care for white. Original color was 14 (signal orange?), and I'd want to return it to that color. I have checked for rust, put it on a lift, there is no rust visible, though I agree some could turn up when it has been stripped. Thanks again
I am in the 40-50K camp as well.
A running drivable, no visible rust real vin 914/6, with a period correct S motor, yeah, 40-50K. Even with the flairs. |
The 9 Store
I agree with 40-50. 25 for the engine, 15 for the chassis. 10 for all the real 6 parts. Just a real 6 dash frame goes for $1k. Many parts on a 6 are specific to a 6. It all ads up.
All used parts sold as is. |
Thanks again to all of you
914 Geek
As I said, I was taking a guess. I didn't realize how valuable the motors had gotten...
BTW, the value for a project car is almost always less than the total value of the parts. Many driver-level cars are also this way, or have been in the past. --DD
So.. does this car have more value because it has the wrong motor (but arguably better motor) or if it had its numbers matching motor? Non original flares? (or is it a unicorn of a car and they are actually M471 flares/optioned car?)
914/6 vin starts at $10K. Condition works out the rest of the value
1970 914-6 Past: 2000 Boxster 2.7, 1987 944, 1987 924S 1978 911SC, 1976 914 2.0, 1970 914 w/2056 |
Is it an original flared car? No idea, and to my knowledge no way of knowing except maybe with a COA Thanks
gearhead
The S engine is worth more than a regular old 914/6 engine, but the value of the car takes a hit because it is no longer numbers matching. It's kind of a wash IMO.
Flares in general are a weird piece of 914 history. The 914/6 GT with flares was something Porsche wanted to homologate for Group 4 racing. In addition to that, what happened in the States was Porsche tried (unsuccessfully) to homologate them to B Production SCCA racing. Since there weren't enough factory ones made, they made conversion kits available as an add on sale through the dealer. As such there are a bunch of GT "replicas" built back in period using real factory parts but not actual GTs according to the COA. I guarantee your car isn't a GT from the factory, but it could have been built up as new or shortly thereafter.
gearhead
Any updates? Did you buy it?
Fast forward 4.5 years...
Yes, I finally bought the car! I couldn't come to an agreement with the seller in 2018 but kept in touch. I was able to buy it late last year. The car has been sitting for the last 4 years and now I need to get it sorted out mechanically. Henry
War Vet
Holy zombie thread Batman!
Dr. Phatt |
gearhead
I only have a few lousy and old pictures. But here they go. I will start recommissioning the mechanics right away and the cosmetics will follow later in the year. Original color is Gulf Orange, and it will be returned to that color.
I have the original bumpers and a second set of Fuchs wheels I'm sure it will turn out nice ![]() ![]() ![]() ![]() ![]()
Registered Minimalist
Very cool! I'm converting a 914 2.0 to a flat 6. Without knowing where you started at price, I'm thinking you still got a deal. A 914-6 is awesome. Starts with all the right bits. 2.2 with Webers is a fun motor.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
I think most of the time it's a coin toss when you buy a car, you hardly ever really know the actual condition until you've had it for a while. Especially with a car that needs a fair amount of work like this one. I think I paid a fair price but the coin toss can still go either way. But I'll still have tons of fun regardless.
gearhead
Sometimes you toss the dice. I’ve got a 1970 914-6 conversion race car I picked up a few years back. It’s got a twin plug supertec 2.8 built on a 75 7R case along with a Wevo 916 gearbox. I bought it for what I figured I could sell the engine, gearbox, and roller for, knowing I was going to spend money getting it right.
Looking forward to following your project. Maybe it will inspire me to dig further into mine.
