911 euro engine value
Looking for help with valuing so that I can sell.
I have a disassembled 3.0l engine from a 1979 911 ROW car. The Case is not separated but all head bolts and bearings look great. I can take plenty of pics. Last edited by Rusty911SC; 09-19-2022 at 01:15 PM.. Reason: Would like more response |
(man/dude)
I wouldn't separate a shell, motor, and trans. I think you're better off the keep the lot together, you'll get just as much for a "complete" project IMO and it will be a lot less trouble.
PM sent on shell
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
disband
what do the heads, cylinders and pistons look like? a fire damaged case could have twisted some getting so heated. looks like the fire was put out quickly by the case but separating it could be the only way to know.
did the early euro SC have a tranny cooler? does the sale unit have one? help those who know here by providing more pictures of the top end.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Would the engine # suggest it’s from a 1969? Specifically a S motor?
‘79 911 SC Euro or ROW
Banned
I’m looking for a 3.2/3.0 case. What are you asking?
gearhead
Rusty,
That user is a bot.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Where can I post this question so that I may get an idea on valuing this engine?
gearhead
One comment that stands out is Juanbenae’s mention of the only way to find out if the case is warped is to split it. Then you would take it and bolt it back together and see if the crank spins freely. This engine might be largely junk. It might be fine. You need to help us help you. Keep posting pictures and adding details. You’ll start to see numbers. You could just list it for sale with some random number but you will get all the same concerns and requests for details. Consider this your due diligence on value. It’s not because nobody wants to help.
Thank you for the comments.
When I was in the process of resurrecting the car, I had three Porsche guys look at the motor in its various states- prior to tear down and after. None of them seemed concerned with case damage. Two believed that it could be put back together without splitting the case and the third thought that in order to rebuild it correctly then i should split the case. When I was directed above to split the case and reassemble it, that only makes sense to me if I am going to go ahead and refinish the halves and install new bearings, etc. I am looking to sell this motor, not rebuild it. |
gearhead
