This is an early sand cast type 901/05 engine,
complete and running with 2.2 L B&P and MFI injection, but there no engine number stamped on it?? any ideas of value? Thnx ![]()
1973.5 911T Coupe yellow '02 Carrera Coupe C4S Black |
Number would not be stamped on that surface. Alu cases are stamped on the pulley side of that casting.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
gearhead
Vasek had a bunch of those cases back in the day. They were used in both race engines and to replace cases on street cars. I would value it around the same as any other 2.2 with maybe a $500-1000 bump because it’s aluminum.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
So a complete and running 911 engine is worth $ 550- to $ 1000-? I think you are still back in the day....
Hi Bill, where is the pulley side of this engine??? thnx
gearhead
Read it again before you make snarky remarks…
ditto to you
![]() thnx
7.0:1 > 11.3:1 > 7.0:1
I think Bill means this:
Thnx Jim
he means 550-1000 dollars more than a similar engine cast out of iron..
If it is a 2.2, would this be for 1970 & 1971?
They are in fact available. Just place a wtb ad and....
lake wales fla
So still no real idea of value from the Beaks?
Saying it's worth more than X doesn't really give a value, does it? I did receive a couple of constructive PMs and emails. The rebuilt MFI pump, new headers and new exhaust cost me over $ 5k, plus mag stacks, on a running 2.2 liter 911 engine would seem to price this in the $ 18k to $ 20K range. Thank you.
War Vet
I wonder if it has to do with your sunny disposition?
Dr. Phatt |
Hopefully
gearhead
