Value of an unrestored 1970 911t
![]() Video - 3 minute walkaround Video - Driving it for the 1st time about a year ago I've been working on this car for the last 2 years to get it into a runner. Please see below for the work that has been done to the car. It runs roughly right now. I hope to get it to the point this summer where I can regularly drive it around on the weekends. After that, I will tackle the body and interior issues. I might also decide to part ways with it and move onto a new project. I'm curious what the value might be in a few months if I decide to sell it. Work performed: - Original Zenith carbs rebuilt - Replaced Marelli distributor with a bosch 02310159006 (curve matches the 911t) - New master cylinder - 4 brake calipers rebuilt - 4 new tires - New batteries - New front struts - Replaced shift bushings - Replaced the CDI box with MSD ignition (model 6al) - New msd blaster ignition coil - New Heat exchangers - New Muffler - Valves adjusted - New oil pressure sending unit Thanks for your time. Regards, Peter
1970 911t - Work in progress. Last edited by pwalke; 03-10-2013 at 03:58 PM.. |
Let me know if selling
So many things to know before naming a price.
Prior body/chassis repairs can deduct significantly if they need to be redone. Much depends on the rust situation on the underside. It could be an $8000 car if there are holes in the pan or a $12000 car if it's decent underneath. If you get it to run smoothly, you can add $2000 or so to the above prices.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
