Yes that is Pasha cloth
redstack's Avatar
84 911 "resealed engine" and wild upholstery
The grey market car I was talking about earlier had the engine "resealed" 10k miles ago. What does this usually entail? I wanted to have an idea of what to look for when I get to spend some time with the car.
One thing that I found was that the seats are this wild black and white check velour material in the middle with probably vinyl on the sides. I actually like it, because there would be less sliding around. Bad part is the cloth has separated from the vinyl on the drivers seat. Is this a fixable item at the upholstery shop?
I have photos I'll try to upload from my iphn.
Looking at the photos it seems like the cloth is split as well. I guess it would have to be replaced anyway. Too bad cause that was way cool in 1974, ten years before the car was built. So any thoughts?
Old 07-17-2013, 10:38 PM
924 seats?.... must be a few survivors left. Pretty awesome, IMHO.
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/737111-identify-front-seat.html
Old 07-17-2013, 11:10 PM
redstack's Avatar
A buddy said something about a 928 he had with possibly this kind of fabric
Old 07-18-2013, 07:08 AM
gearhead
Yes, 928.
Old 07-18-2013, 07:16 AM
redstack's Avatar
But the back seat matches the fronts. That can't be swapped can it.
Old 07-18-2013, 02:38 PM
Quantum Mechanic
mpetry's Avatar
Send a message via Yahoo to mpetry Send a message via Skype™ to mpetry
that upholstery could have been a special order option. What's the cost of a COA these days ? $125 ?
Mark Petry
Bainbridge Island, WA
81 SC
Old 07-18-2013, 07:42 PM
Thats called PASHA ----- seen more frequently on European 911s
THERE IS A TEXAS BASED UPHOLSTERER WHO OFFERS A LEATHER VERSION OF THIS AS PER BELOW :
Old 07-18-2013, 09:51 PM
redstack's Avatar
Thanks Nomadic
looked up the post you mentioned. Found the material for sale in Germany for $100 / meter. One fellow said it takes three meters of cloth.
Old 07-18-2013, 10:47 PM
techweenie's Avatar
As others have said, that's an optional factory fabric. It was used more commonly on the 928. And as is often the case with Porsche materials and colors, was despised and now is valued.
An upholstery shop can probably make wider versions of the vinyl side panels and stitch it back together.
As for the 'reasealed' engine, that description is used to cover a variety of things. Most often it's disassembly of the "top end" and replacing oil return tube seals, chain housing seals, etc. At its most extreme, it could mean splitting the case and resealing case halves (unlikely, because that becomes a 'while you're in there...' activity)
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 07-19-2013, 07:35 AM
Kraftwerk's Avatar
I love that fabric. See it on a lot of european 911's
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 07-23-2013, 12:11 PM
