Mighty Meatlocker Turbo
Excellent highlight action for sure! One good thing about the headstuds is that it's easy for a shop to verify that they are not broken, or pulled, by simply removing the rocker covers during a PPI inspection - the tops of the studs, along with the nuts ( ) are very visible, and anyone with experience would be able to tell you right away if there were any that were a cause for concern. That really is a "must do" as a broken stud is very expensive to fix and should affect the sale price tremendously.
I mentioned I'm also looking at an 86 Targa with around 109K miles for 42.5K. Seller purchased from widow for 15K and then put 20K into exterior glass out respray, etc. I'm going to see it this Saturday. He's second owner and hasn't driven but for a few hundred after work was done. Is 20K simply a crazy good exterior refresh or is that typical? Also, has full papers from all services done by one porsche shop. I should have pics tomorrow and will share.
Seller shared: We had new clutch installed 5/16. New michellin pilots, new Porsche targa top, 20,000 complete exterior cosmetic restoration from Porsche certified shop. |
<insert witty title here>
The valve guide issue was discovered during the PPI when I had a compression and leakdown test done. Each shop would probably have a different list of items to check on a PPI, but I always make sure they do a compression and leakdown test to gauge the health of the engine. Doing so will also turn up any broken head studs. In my opinion you should have those tests done on any air-cooled engine (not that they're any more or less susceptible to problems, but it's more of an age/mileage thing - compression/leakdown aren't likely to be a problem on a 5-year-old car). You should also ask to look for evidence of undisclosed accident damage. This can be found both with a paint meter (differing paint depths on different panels) and by looking for repair work underneath (could be welds, bent and straightened pieces, etc). If it's costing you $100, the mechanic isn't going deep enough. It should run about $200-400, depending on the shop. Usually at least $300 including compression/leakdown. If the compression test shows one or more bad cylinders (beyond the acceptable figures based on age and mileage), going deeper than that involves removing the engine and getting in a lot deeper, which means more money. At that point you should be either negotiating with the seller to lower the price or moving on to another car. When I bought my 87, I PPI'd another car that had a bad compression test. The seller wasn't willing to lower the price to where I was comfortable taking a risk on a motor that might need a full rebuild, so I passed and moved on. With the car I bought, we negotiated the top-end rebuild into the sale price that was (if I remember correctly) slightly higher than his original asking price, after I'd negotiated it down a bit (or maybe it was the same as the asking price). He paid the bill for the rebuild and I paid for the headstud replacement as well as some regular little stuff that turned up on the PPI. I had the headstuds upgraded "while you're in there", just as insurance against future problems. In the end we were both happy with the price.
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
Most flippers lie about what they've invested in the car, to make their profits look smaller. Remember, they're just a nice guy helping you make a deal, and taking a few bucks for themselves.
1986 Bosch Icon Wipers coupe. |
i just sold a very nice 87 targa with 77K miles for 44K. probably could have sold it a bit higher to a fellow in germany who was interested . definitely do a leak down and compression-- low mileage cars often suffer here.
Michael |
Hey all
Took a look at the 86 Iris Blue Targa with 109K mi, and talked with the owner a fair amount. As mentioned above, the exterior was brought to the metal, repainted, seals replaced and targa completely refurbed. The new information shared is that included with the repainting was metal work on both rocker panels to eliminate rust. In talking with a local shop specializing in "torsion bar and air cooled" Porsches, he said for starters the asking price of 42.5K was high and couldn't be justified without having engine and tranny, and perhaps even some suspension work already done. Additionally he shared the most concerning detail for him is the rust in the rocker panels. Said he seldom sees that type of work required unless there was a collision and/or significant rust involved. Suggested I think long and hard, making sure I'm exercising my patience muscles! Thoughts? Again, thanks for all your input and teachings! Forgot to mention he said 1 or 2 cylinders had lost "some" compression, which for the shop was also a red flag. Then rotors and pads are needed 1K in parts, front seats need redying/touch up for 150/each, and eventually carpeting. Last edited by Ski; 02-15-2017 at 06:42 PM.. |
Pics?
Just spoke with seller-for-owner of 89 Targa with 59K mi and selling for 49K. Said lead down/compression test showed 5 cylinders at 180, but one at 140. From all I've read, having the one cylinder at different level is not good. How bad is the fact it's inconsistent and by that much?
Said current owner drove last 15K miles as daily driver whereas prior owner had as part of collection so it sat quite a bit. Also, said he doesn't see smoke and pulls strong... Finally, I'm thinking it would make sense to have a Pelican check it out before I ask for PPI. What's the process to see if someone in Atlanta area can help? Do I simply create a new post/thread asking for the help? Thanks! |
What are the leak down % numbers? If they are all lower than 10% (preferably between 2-5%) the engine is healthy most likely. I wouldn't worry about the 180 compression too much.
I'll see if I can get that metric. I got the sense I wasn't getting the right numbers when he shared "180s" and "140", but no matter the exact numbers, I was and am concerned about the difference in one cylinder. Good call on asking for the actual numbers and more importantly, the %. Thanks! |
We need both test results, the exact numbers. It will help us determine the condition of the engine. |
Ski, if the cylinder that showed the lowest compression number also showed a troubling leakage percentage, then that would be something to be concerned about.
Also, ask the tech if he was able to determine the source of the compression leakage (past rings = hissing sound in the oil tank, past intake valve = hissing in the intake, past exhaust valve = hissing from tailpipe . . . or was it leakage from between a cylinder head and cylinder = broken or pulled headstud). Last edited by Rawknees'Turbo; 02-17-2017 at 07:13 PM.. |
Charles 88 911 Cab 74 TR6 88 CRX Si 79 930 #632 (sold her and survived her) |
Would greatly appreciate getting your perspective! Thanks, Kevin Last edited by Ski; 02-18-2017 at 08:09 AM.. |
Will do. I'll even sound like I know what I'm talking about!
