Secondary air low flow cyl 4-6 fault code
Anyone know what to do about this code on a 97 328iS? (It's code F6 on the Peake tool). I'm guessing this fault is caused by a low oxygen content in the exhaust. It gets thrown only after the car is warmed up and when it's idling. If it's a bad air pump, wouldn't both banks throw a code? So could it be a bad O2 sensor or dirty plugs?
Thanks for your help!
Old 04-02-2003, 03:13 PM
Send a message via AIM to Rob83xzman
I just got this same problem. DId you ever figure this out?
ROb
robandchristina@cox.net
Rob
Old 09-30-2003, 09:35 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Sounds liek a faulty catalytic converter.
Old 10-01-2003, 08:23 AM
