repalcing spark plug end
hey guys, how do i replace my spark plug connector? the one that connectors the the plug. does it just screw off?
thanks,
-mark
Old 02-17-2004, 01:36 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Why do you want to replace just the end? I'd say just replace the whole set..
It should just pull off, but you have to make sure that the contacts match up inside.
Old 02-17-2004, 01:37 PM
pull off? thought it would screw off? i am talking about the part that connects to it. reason im not doing the whole set is because this is the only bad connector.
Old 02-17-2004, 01:55 PM
Whats wrong with the connector? Did you check resistance in the line?
Old 02-17-2004, 01:58 PM
it doesnt want to stay on, and its cuasing my spark plug to come out. it doesnt click when its pushed on like the other ones.
Old 02-17-2004, 02:02 PM
Look on the inside of the connector and check that the clip is still there. Sometime you can fix it with a pair of needlenose pliers..
Old 02-17-2004, 02:05 PM
also the spark plug keeps coming out, would a brand new one fix this? the inside of the connector isnt clean and shiny like the other ones, its dark and beat up looking.
Old 02-17-2004, 02:57 PM
How are the threads on the head that hold the plug in.. Thats what I would be more worried about.. If the threads are stripped, you'll have to have the head heli-coiled.
Old 02-17-2004, 03:03 PM
it hasnt done this until abouit a month ago, can it just strip for no reason? coups the plug be bad?
Old 02-17-2004, 03:11 PM
