radio code
When I go to put the 5 digit code on the radio I hear a loud beep before I get to the fifth digit. I tried leaving the key on for a few hours,but still I get a beep before I can get the code entered. Any help would be appreciated. Thanks Joe
Old 04-18-2004, 05:52 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Might help if you tell us what year and model it is....
Old 04-19-2004, 07:09 AM
supertack's Avatar
LOL.
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 04-19-2004, 11:40 AM
sorry 1993 325i. I tried today but as soon as i hit the 2nd digit it beeps. Thanks Joe
Old 04-19-2004, 04:50 PM
Did it start doing this all of sudden? Have you recently disconnected the battery or done any other work to the car?
Old 04-20-2004, 07:05 AM
The car was in an accident,so the battery went dead from sitting. I called the dealer to get the code punched in the code and it worked fine. I replaced the old battery with a new one and now all I get is a beep when I get to the third or fouth digit.
Old 04-20-2004, 10:17 AM
Hmm, little confused the code worked fine with a dead battery? Or after you replaced the battery..
Old 04-20-2004, 03:35 PM
The radio worked fine,I disconnected the new batery by accident and now I got nothing
Old 04-20-2004, 03:53 PM
Saintly's Avatar
Try disconnecting the battery again and wait for a few mins before you re-connect it. Then try the code again.
You could also try starting the engine first incase it's an issue with low power.
Saintly
'97 318Ti Sport, DASC, H&R coil overs (sold)
'07 F800ST
'10 Forester X Special Edition
Old 04-20-2004, 04:15 PM
