check engine fault code 1222 on 1992 325i
I got the 1222 code from the car, so I changed the 02 sensor hoping that would solve the problem, but it didn't. The car hesitates under acceleration and especially at slow speeds. Anyone have any ideas? I've done all of the regular stuff, new plugs, new air and fuel filters, new 02 sensor... nothing worked so far. Also when the car reaches normal operating temp, it is impossible to keep running. Car stalls either sitting at idle or as soon as you try to accelerate. If anyone can help I would appreciate it so much!!!
In the shop at Pelican
Sounds like you may have some vacuum leaks..
I wonder, because even after replacing the 02 sensor, I still get the 1222 fault code, so it seems like an emissions related problem. Any thoughts?
How did you check the codes? Scanner or gas pedal trick?
gas peddle trick is how I retrieved them.
not to Hijack your thread, but how do you do the gas pedal trick. I've tried it and it hasn't worked for me yet. My check engine light DOES NOT come on when i start the car up normally. i wonder if that's a problem?
You should be able to find the BMW OBD-I gas pedal trick on the web easily. I think it is something like, turn ign to ON and press the pedal to the floor 5 times but I've never done it.
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 |
Author of "101 Projects"
Here are the instructions you're looking for:
http://www.pelicanparts.com/BMW/techarticles/Mult-Code_Reading/Mult-Code_Reading.htm -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
