Window won't operate
My power windows won't work. If you pressed the buttons enough they would eventually go up or down, now, nothing. I can hear a buzzing in the door when you press the button. Is there maintance or rebuild you can do to the motors? How can I check the swithches
1986 325e
Old 12-06-2004, 04:42 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
does it do this on all the doors?
sounds like the motor may have jumped a cog or something.. Cant do much with out more info or seeing a pic of the inside of the door.
Checking switches is easy... I highly doubt all the switches failed at once, so you just pull them out of the console, and swap them. if th switch doesnt work, you'll know...
Old 12-06-2004, 11:29 PM
Ok... the driver side went first and while the passenger side was still working (occasionally) I switched switches. No luck. Now, as I said, both power windows are out. With the price of the window motors, I wanted to cover all the bases before I had to spend a lot of money. TIA. 1986 325e
Old 12-07-2004, 01:11 PM
intermittent operation would suggest that possibly the motors are worn, however its pretty unusual that both would fail at the same time
Old 12-07-2004, 09:38 PM
Thanks for the help. I'll dig into it a littlle more and get back to you.
Old 12-08-2004, 09:57 AM
Simon S's Avatar
'91 318is (work in progress) / '88 Integra LSs (227K mi winter/hoop ride)
Old 12-08-2004, 11:33 AM
Thanks Simon S that did the trick for the passenger side switch ( really gunky) The driver side was just as dirty. Except when I push the driver side switch I hear a ticking noise in side the door, with no movement.
Old 12-09-2004, 11:12 AM
Take off the door panel and have a look inside..
Old 12-09-2004, 09:50 PM
Did just that.... hit the window motor with a wrench and it started working. I greased the window tracks and it works like a charm. Thanks for all the help.
Old 12-11-2004, 11:26 AM
No problem... Sometimes it's just that simple...
Old 12-11-2004, 10:36 PM
