supertack's Avatar
Part Number?
Folks,
I am looking to replace my center air/heat vent on the dash. I'm getting contrasting part numbers, & want to make sure I get the right one. I have a '97 328is, & am wondering if all e36 center vents will fit my year.
1. what is the actual part number?
2. is there a cut off (years) that will fit my vehicle
3. how tough is the install - tech article, ect?
As always, thanks much.
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 06-13-2005, 04:54 AM
supertack's Avatar
Anyone have an idea about this? I wanna make sure older ('92-'96) e36 center vents are compatable with a '97.
Does it matter if it came off a convertable, sedan or coupe?
97 328is
Old 06-15-2005, 03:58 AM
Jeron's Avatar
Try this:
http://www.realoem.com/bmw/
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 06-15-2005, 08:47 AM
supertack's Avatar
Thanks, .........but no dice there either.
97 328is
Old 06-16-2005, 04:21 AM
Jeron's Avatar
I don't understand. It had a ($55) part number listed for yours.
Can't you check compatibility by getting the part numbers for the other cars in question. Or is it that the part numbers ARE different and you don't know why? Give me an example?
Old 06-16-2005, 08:51 AM
supertack's Avatar
Oh, maybe I'm not looking right. After I put in my vehicles logistical data, It gave me searchable criteria, ie. engine, drive shaft, lighting, ect, ect. I didn't come across anything that remotely resembled that area or part I'm lookin' for. Help me out, would ya. What am I doin' wrong?
97 328is
Old 06-17-2005, 04:16 AM
Jeron's Avatar
I think you arent scrolling down in the "Main Group:" list box
After you select your car click [search for parts] and you'll get the "Diagram Selection" page.
Scroll down the "Main Group:" list box and select "64 Heating and AC"
Then select "64 05 Air Duct"
At the bottom it shows your part. Click it and get the part list.
http://www.realoem.com/bmw/partgrp.do?model=BG13&mospid=47485&hg=64&fg=05
http://www.realoem.com/bmw/showparts.do?model=BG13&mospid=47485&btnr=64_0757&hg=64&fg=05
Old 06-17-2005, 08:19 AM
supertack's Avatar
Excellent. Thanks for the help.
97 328is
Old 06-20-2005, 04:44 AM
