Question Signaling light problem
1991 325I, 112,000K
Occaisionally, one of my signaling light will flash rapidly and then return to normal? What could be the cause of this?
Jason
Old 06-21-2005, 05:53 PM
Could be a faulty socket. Scrub the inside of the socket with something abrasive (wire brush) trying not to damage anything. Usually if the bulb is good and it's doing this there is a fault somewhere on the line or the socket is not connecting with the bulb. If you can rule out a faulty (dirty, corrosive) socket and the bulb, the problem is probably a faulty wire. Good Luck!
Old 06-28-2005, 06:56 PM
