| Registered Join Date: Aug 2004
				 |  Signaling light problem
			1991 325I, 112,000K Occaisionally, one of my signaling light will flash rapidly and then return to normal? What could be the cause of this? Jason | ||
|  06-21-2005, 04:53 PM |
| Registered Join Date: Sep 2004
			Could be a faulty socket.  Scrub the inside of the socket with something abrasive (wire brush) trying not to damage anything.  Usually if the bulb is good and it's doing this there is a fault somewhere on the line or the socket is not connecting with the bulb.  If you can rule out a faulty (dirty, corrosive) socket and the bulb, the problem is probably a faulty wire.  Good Luck!
|  06-28-2005, 05:56 PM |
