Failed LEDs on 11-Button OBC Display
Is there any way to repair the failed LED segments on the 7 or 18 button clock/data display unit? Is the only solution to purchase a new unit?
Old 02-05-2006, 07:39 PM
Jeron's Avatar
Yes, I think we have discussed it in this forum before. If you dont find it let me know and I will search for you.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 02-06-2006, 08:05 AM
Thanks for replying, Jeron. I must have used bad search criteria because I was not able to locate the posts that you referenced regarding repair of the E36 LED obc display. If you could find the information and point me to it I would greatly appreciate it. Thanks again.
Old 02-06-2006, 02:39 PM
Jeron's Avatar
These might not all be for your car. But this ought to get you started. If you still don't find what you need let me know.
Light for in-dash computer
http://www.unofficialbmw.com/repair_faqs/obc.html
http://www.bimmerdiy.com/e36
http://forums.bimmerforums.com/forum/showthread.php?t=289381&highlight=obc
http://forums.bimmerforums.com/forum/showthread.php?t=311638
Old 02-06-2006, 02:48 PM
Found exactly what I needed to know on one of the bimmer forums: http://forums.bimmerforums.com/forum/showthread.php?t=289381&highlight=obc. Thanks again for the help.
Old 02-06-2006, 03:57 PM
hi dave
I have been trying to open the link but it is not working. Can you confirm if it is possible to repair the bad pixel on the LED.
Old 02-10-2006, 01:50 AM
Hi adey,
The LED fix that is proposed in the bimmer forum replaces the backlighting for the 7-segment display - after thinking about it, I'm not sure this will fix my clock - I've got some LEDs that have maybe 5 of the 7 segments working so why would the backlighting make any difference? I guess if the entire LED was dark then maybe the backlighting is the likely cause, but with only certain segments of each LED bad it may be a more serious issue with the electronics.
Old 02-10-2006, 04:44 PM
Jeron's Avatar
May be a bad solder on the LED's in question. That seems to ring bell.
Old 02-10-2006, 08:18 PM
thanks dave
Old 02-13-2006, 12:04 AM
