Weird static from speakers?
Hi, I have a 1998 328is. This morning when I turned on the radio, there was some static coming out the speakers, like a semi-fuzzy radio station. I don't believe it's the speakers though because I faded the speakers to the front and back, and did the balance from right to left, and static comes still comes out, so i highly doubt all the speakers got defective overnight. Anyone know what it could be? Thanks!
Old 11-29-2006, 09:36 AM
Jeron's Avatar
bad radio
bad ground
loose antenna wire at radio or rear window
Does the volume of the static change when you change the vol on the radio?
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 11-29-2006, 10:00 AM
Hmmmm.....when i got into my car last night, it was not staticky. After the car sat over night, this morning was quite cold (for california) about 50 degrees, and when i turned on my car, the radio was staticky again. I kept it on and as i was driving, the static would diminish and after about 3 mins, it was gone.....what could cause that? how weird...
Old 11-30-2006, 10:34 AM
Does it increase/decrease when turning volumn up & down??~~>BMW Radio??
Old 11-30-2006, 05:57 PM
Yes, I tried it this morning, and the static DOES increase/decrease when I turn the volume up and down.
Like yesterday, when i turned my car on first thing this morning, there was much static, and from 0-3 minutes, it got less and less, and then by about 3 minutes, no more static...
Yes, BMW original radio....
Old 12-01-2006, 10:16 AM
Jeron's Avatar
Try this guide:
http://www.crutchfield.com/S-7IVgTNk3P3k/support/faq.html
Old 12-01-2006, 10:26 AM
Hmmm....thanks for the link, but I'm not sure which topic applies to my issue. Do you know what the issue even is by any chance?
Old 12-01-2006, 01:16 PM
Jeron's Avatar
They have 4 guides there that discuss what can cause noises. The most common I think is a bad ground.
I would check the connections at the antenna on the rear window. I would pull the radio and check the connections in the back. Then I would buy a radio because the stock radios are cheaply made and new radios are cheaply had.
Old 12-01-2006, 01:23 PM
I second that! My higher end Alpine radio/CD player (Model 7894)was a substantial improvement over stock, with much more control over sound quality.
Better rear speakers and bypassing the BMW amp for them did wonders, too.
David Frost
Formerly smitten by a 1993 325i Sport with 170K+ miles. Now infatuated with an Audi A3 2.0T DSG.
Old 12-01-2006, 02:19 PM
BMW Roundel
This is a common problem~~>heres how you fix it!!~~>Get some electrical contact cleaner or brake clean->pull radio--> in the holes by the volumn knob on the sides and top/back
of radio===spray cleaner all inside~~>let dry & reinstall
Get a towel and some rags so it doesnt drip everywheres
Old 12-02-2006, 11:38 AM
Jeron's Avatar
BMWCowboy has a history of good info.
Personally, I'd take it apart and clean it so I could make sure it is clean and dry aftwerwards.
Old 12-04-2006, 06:08 AM
Sorry for the late response, was away on the weekend. I will try what you guys have suggested and let you know. Thanks for the tips! =)
Old 12-04-2006, 03:10 PM
U dont have to even unplug radio~~>all ur doin is sprayn the backside of the volumn knob ( use the little straw that comes w/can & turn knob couple times) ~~>make sure NOT to get spray on black plastic of radio
Old 12-04-2006, 05:00 PM
