Ignition problem
seems my 91 318I isn't firing @ the #3 coil
I've checked for volts at the connector it was good
When I checked for resistenance however I got none
I'm not sure the direction I should go next
Any ideas????
ED
Old 02-17-2007, 01:20 AM
i don't know the 318, but are there individual coil packs for each cylinder? if all other coils are operating properly, and receiving adequate voltage, and said coil is receiving adequate voltage, but no output, then bad coil.
Old 02-27-2007, 05:36 PM
fastfredracing's Avatar
Try swapping coils from the bad cylinder to a good cylinder , and see if your miss moves with the coil, if it does, bad coil, if not and the coil is not getting the correct signal, hmm.. dme unit, cam sensor, wiring???
No left turn un stoned
Old 03-15-2007, 05:37 PM
Jeron's Avatar
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 03-16-2007, 09:13 AM
