Replacing battery and losing memory
When replacing a car battery and I want to lose the memory on car radios, etc, can I just hook up a battery charger to a plus terminal block and a ground underneath the hood instead of using a memory saver like the one in the link below?
http://www.etoolcart.com/index.asp?PageAction=VIEWPROD&ProdID=3623
Old 03-16-2007, 06:34 AM
Jeron's Avatar
The battery charger 'might' work but I would not do it. Why not get a memory saver or just jumper cable another car battery to yours during the change.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 03-16-2007, 09:17 AM
supertack's Avatar
I second Jeron's suggestion.
[IMG]http://www.************//assets/product_images/tool/memorysaver.jpg[/IMG]
Memory Saver Tool
Prevents loss of computer and radio codes when your BMW's battery is disconnected. Plugs into lighter socket--uses a 9-volt battery (not included).
BavAuto
(In the 'tools' section)
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 03-16-2007, 10:16 AM
