Turn Signal Not working - 92' 325i E30 M20
hello, I recently had problem with timing and overheating due to a 20 mph head on crash. everything is fixed now with the help of Yurick. I've got one more problem other than fixing my steering air bag. The signal lights are not working. It doesn't work at the dash or at the bulb and the fuse is OK. And the emergency Hazard flasher doesn't work. I think what ever is causing this controls both.
Could be be the Hazard Flasher Relay? And does this control both?
Can someone guide me through this task?
Best Regards
Scoot
Zoom Zoom
Old 07-06-2007, 12:33 PM
I Found a wiring diagram for the Turn/Hazard Lights. Can someone guide me through this. I am lost when it comes to the electrical stuff.
many thanks
Scoot9
Zoom Zoom
Old 07-08-2007, 06:22 AM
I knew this would be a difficult question to answer but I thought I would ask anyway.
Best Regards
Scoot9
Zoom Zoom
Old 07-13-2007, 09:51 AM
Jeron's Avatar
My guess would be a relay.
Also, your model may be equipped with a mechanism that turns on the hazards in the event of a crash. That mechanism may be causing the problem.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 07-13-2007, 11:55 AM
Jeron's Avatar
crash control module or crash control relay might be the correct name
but it could just be the flasher relay
Old 07-13-2007, 12:00 PM
thanks for the reply Jeron,
Is the flasher relay located under the steering wheel? I have the wiring diagram but it doesn't pin point exactly where it is and what it looks like. I've also been told it could be the flasher switch??
thanks
Scoot9
Zoom Zoom
Old 07-14-2007, 04:44 AM
Jeron's Avatar
The relays are under the hood by the brake booster, under the steering wheel and behind the glove box. The Bentley manual should tell you where each one is.
Old 07-14-2007, 06:25 PM
yea i need to replace my flasher relay too. Im pretty sure its in the steering wheel. I've got one screw under the steering wheel is this where I start and how hard is it to get to? My car's a '90 325i.
Old 07-19-2007, 03:42 PM
