Mike
Check control messages
I am getting a check control message that says "brake light circuit - check owners manual". The owners manual doesn't cover this particular phrase and neither does my Bently manual. What does this mean? Is this a bulb failure or something more concerning? The car is a 1997 328i Sedan with automatic transmission. Please help...
Old 11-29-2007, 02:51 PM
I would check the obvious first - brake lights.
Old 11-29-2007, 05:53 PM
The Man
Send a message via AIM to whosyadadie01
i got a similar message of brake light failure ... all the lights work just dont no why it says it ... seems to be a common problem with some on the e36"s
BMW e36 96 328I convertable
Old 11-29-2007, 09:10 PM
if it says brake light circuit you need a brake switch. and for the brake light failure if all lights are working pull each one out and see if the bottom of the bulbs are burnt or the sockets.
gONe
Old 11-30-2007, 03:39 AM
The Man
all the lights work but i had to do a little repair job on one of the lights being that one of the contacts got melted and i had to bypass it with a peice of wire lol ..... and 911sculler i dont mean to steal your thread just trying to get my problem adressed at the same time
Old 11-30-2007, 05:44 AM
I've had it happen a couple of times - and after searching various forums I've just ordered the switch! Seems to be a fairly common problem.
Old 11-30-2007, 10:28 AM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
BTDT. common problem. you need a brake switch. its above the brake pedal under the dash. part available from our host. fix takes 10 min.
http://www.pelicanparts.com/bmw/catalog/shopcart/BE36/POR_BE36_ELswch_pg4.htm#item28
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 12-01-2007, 01:45 PM
It does take 10 minutes. Just a piece of advice: Crush the old switch out with vice grips. The switch self locks in place and is very difficult to remove being civil. Have fun. K.
Old 12-05-2007, 11:23 AM
Mike
Thanks for the help everyone! I just ordered the part and will be replacing it as soon as it gets here. Thanks again for the help!
Old 12-13-2007, 03:56 PM
