| Registered Join Date: Feb 2007 Location: Atlanta GA
				Skip in idle from cold start.....
			I've noticed a skip in the ignition when starting from sitting over night, after I run the car for about 5 minutes or so idle gets normal, but I believe its some kind of ignition problem, if a cylinder was mis firing wouldn't that cause backire??  I think one of my wires is or the connection is bad, or maybe its a plug fouled, I'll check it out when I get the chance, only other guess would be a fuel issue to one of the cylinders....??? Any thoughts??
				__________________ 95 318is, stock, burgundy exterior, 2 one baige interior, automatic, 180kmiles | ||
|  02-18-2008, 04:01 PM |
| Moderator |
			Have you looked at the plugs? No check engine light?
				__________________ HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 | ||
|  02-18-2008, 05:48 PM |
				 |  Major firing issue...
			Skip has gotten worse, I believe my coil or wires are bad, stumbles when driving from low speeds 20-40mph, vibration when idling and rough...
|  02-25-2008, 02:02 PM |
