Mr. Diety
43rdworld's Avatar
Temp switch question
I've done some research on this but haven't found a definitive answer. I need to change my temp switch (the one on the radiator). How much coolant do I need to prepare to lose - a little or a lot?
Also afterwards, do I need to bleed the system or no?
Thanks much in advance.
Old 09-02-2011, 11:07 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Did you read the top of the forum?
Please include the year and model in your posts.
Old 09-02-2011, 11:49 AM
Mr. Diety
43rdworld's Avatar
98 323is
Old 09-02-2011, 05:08 PM
You'll need to drain the coolant at least to the bottom of the temp sensor. This should be on the upper right hand corner of the radiator. It won't be much coolant. You could probably just get by with distilled water (IMPORTANT, not water from the tap). Afterwards, crack the bleeder.
Old 09-06-2011, 09:08 AM
