| Registered User Join Date: Jan 2012
				instrument cluster problems
			whats happening to my 325is? lately the instruments and working fine and then they drop to the bottom and then maybe they will start working again in a few minutes or seconds, everything quits  at the same time, Any help would be great
|  01-02-2012, 04:30 PM |
			sorry  I forgot to tell its a 1994 325is  thanks
|  01-02-2012, 05:16 PM |
| Registered User |
			Most obvious thing on something like this is loose wiring.  If the entire cluster goes out, a major ground?  Intermittent electrical problems are devil spawn. From experience I know the car will run with the entire cluster out of the car - With the multiple connectors on your dash I just don't know of any one thing that would make everything quit. Henry | ||
|  01-12-2012, 06:42 AM |
| In the shop at Pelican Join Date: Aug 2002 Location: Los Angeles, CA
			It's probably a ground issue. You should check all the connections and ground points. Older BMWs have this problem pretty often.
|  01-12-2012, 09:00 AM |
| Registered Join Date: Nov 2002 Location: Burke, Virginia
			I've had two M3s and a 325i and have had this problem with all the cars.  It also disables the cruise control when it goes out.  I suspect that it has to do with the fuse block.  I've found that if I start the car and the instruments dont' work, remove fuse 31 and reinsert it, this will correct the problem until it does it again.  This isn't a permanent fix, but will make your instrument cluster workfor the short term. Clear coat peeling is another issue I've had with all my BMWs. | ||
|  01-24-2012, 06:14 PM |
