Anthony (guest)
Guest
Posts: n/a
When i unscrew maf sensor a little it works out air flow and it runs just fine but if i have it screwed all way down like it suppose to be maf sensor it jumps up and down and doesnt run to great,,,,
This post was auto-generated based upon a question asked on our tech article page here:
Old 05-07-2014, 04:58 AM
Nick at Pelican Parts's Avatar
I'm still not sure what you are unscrewing. The electrical connector or are you pulling the sensor out of the duct?
This is not a test that means anything to me. So the result is null. IF you are having an idle issue, look for broken intake air boots, vacuum leaks and fuel delivery issues. I would start by checking the DME for fault codes. If the system is not working properly, a fault code will be set. This will be your best bet when diagnosing.
- Nick
