connector in engine bay
Anyone that can tell me what this connector is for in a US 79 930 ?
A guy her is asking, and I remeber I've seen it. Just can't remember what it is for. Is it for a valve in the air pump system? ![]() ![]()
Trond R. 1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc.. 1972 914-6 GT replica project 1986 944 Turbo |
Think I found out from another thread
Air Thermo Valve ![]()
You probably know it but two 10mm wrench size nuts are missing just below the plug you're asking about. You shouldn't run the motor and blip the throttle or drive the car while they are missing.
That's correct, those vacuum hose's should be connected to the smog air pump diverter valve.
1986 944 turbo -first car 1997 993 Cab 6 speed-sold 1992 964 C2 turbo SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo |
