Twin Turbo exhaust header sizing
Hi all back on the Dyno and yes still chasing my tail... fabricated new intercoolers thinking this was choking the engine. But with new setup engine still will not make decent power we up up to 358.7HP @ 1.2 bar boost .at the wheels ..now we are thinking maybe the header pipes are to small they are 32mm going to turbos ... i am still waiting on confirmation from engine builder on exhaust port sizes... I am running Dougherty 993SS cams and engine builder assures me there are setup correct....
So any ideas where the ponies are hiding... i assumed i would see around the 600HP at the wheels ...
Old 07-15-2019, 03:04 PM
32mm primary pipes are really, really small. What other options do you have available?
Old 07-15-2019, 03:16 PM
lite75's Avatar
Those are small primaries for sure. What size are your exhaust ports?
75 930, 76 930, 83 SC EFI turbo
Old 07-15-2019, 03:36 PM
Brando
quattrorunner's Avatar
Wow!
Turbo powa!
1977 911s. it's cool
Old 07-15-2019, 04:05 PM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
What turbos do you have?
Old 07-15-2019, 04:23 PM
TurboKraft's Avatar
On a 98mm 3.4L Twin Turbo? Try 1-5/8" O.D. tubing for the primaries, that's 1-1/2" ID (38mm).
32mm ID = 1.26" ID so ~1.375" (1-3/8") OD, assuming standard 16-gauge SS.
We don't use anything that small even for wastegate dump pipes.
What possessed your fabricator to use something so small? All he'd have to do is hold a tube up to a head's exhaust port and know he's starting out wrong.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 07-15-2019, 05:35 PM
I would rather be driving
jpnovak's Avatar
Don't think its the Zork Tubes.
Agree. Primaries are too small. I bet they are really glowing trying to get that much air through them.
Old 07-15-2019, 06:28 PM
Twin turbo header sizing
Hi all ...well spoke with engine builder and as it turns out i have 39mm intake ports and 35mm exhaust ports and the inside diameter of the header tube is 32mm...
there lies my problem..... this is an oversight on my behalf i cant throw anyone else under the bus... so i think i will need to fabricate new headers in 38mm i/d tube ... will be tight around the head studs but will have to work through it...does anyone have pictures of there headers ...
I think now the car is running and driving i will finish painting and assembling it put a few KMS on the car then do the pipes...
Old 07-15-2019, 09:47 PM
Crotchety Old Bastard
RarlyL8's Avatar
1 3/8" primary tubing? Yes that's going to choke things pretty good.
At 35mm your exhaust ports are not very large which also may be a limitation. A 1.5" primary header would work with them nicely if low and mid range torque is the goal. Transitioning from 35mm port to 38mm primary will lose velocity but allow more top end power.
We've done a few rear mount twin turbos using 1 5/8" primary tubing with 38mm exhaust ports. Below is a set we built recently. I'm planning another twin turbo build and just completed a second set. If you would like them give me a call. Should be easy to adapt to your current setup.
Old 07-16-2019, 04:54 PM
Rarly PM sent...
Old 07-16-2019, 06:02 PM
He's looking for 100hp/cyl. I'd be more inclined to go 1 3/4" primaries, even if he had to use a 1 5/8" step at the exhaust port.
Which turbos is he using? The steps could even help the power if it has modern turbos.
Old 07-16-2019, 06:59 PM
RarlyL8's Avatar
Choke point is the 35mm exhaust ports. Larger primaries would just create a lag monster.
Old 07-17-2019, 05:26 AM
How about a pic of the dyno sheet? While it sure sounds like you have a header diameter problem I don’t think I would go straight after that without first trying to optimize what you have. That number is low in spite of the header diameter.
AF ratios, boost and timing logs would be great!
Old 07-17-2019, 06:06 AM
1 3/4” not needed at 600hp. Even 700hp seems to be ok with 1 5/8” from what I’ve seen.
Just as another point of reference, with 1 5/8” headers I made 430whp (mustang awd dyno) at 6psi of boost. Granted this was a 993 on 100oct so not apples to apples. I focused on all the same airflow items that make for a good NA build and then put some boost to it.
The OP needs to look at the entire system for choke points. The dyno plot really helps tell that tale.
Old 07-17-2019, 06:08 AM
Sounds like the OP needs to massage/open up the exhaust ports, too?
Old 07-17-2019, 07:44 AM
Firstly thanks all for the input ..this is why i love this forum... second to achieve around the 650-700HP what should the cylinder head intake and exhaust port sizes be.. i know there is a combination of factors to achieve this but lets start there..
Also what combinations are people running to achieve BIG HP numbers...
Old 07-17-2019, 03:09 PM
The later air cooled 935's used 43mm and 41mm ports. With 1.4bar boost made around 750hp, give or take.
Old 07-17-2019, 04:04 PM
TurboKraft's Avatar
Is 800whp enough for you?
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 07-17-2019, 04:28 PM
Hi Chris what engine combination could make that sort of power... i always thought getting those real world numbers was a myth ...
Old 07-17-2019, 04:36 PM
BA_sprint_4
Old 07-17-2019, 04:44 PM
