I drove the car for about 1000 miles with a lot of boosted sprints of course, last week I took the turbo off to add a oil drain tank, and it looks brand new with no play in the shaft, so I think it will hold up just fine. Mind you that although its Chinese, but it wasn't a cheaply made one, it has a lot of positive reviews accross the internet, its sold under the brand name "Pulsar Turbos" in ebay.
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management. -1987 Carrera Coupe. -2013 Carrera S PDK Coupe, factory Aero Kit. My DD. -1987 928S4. |
No issues with welding on the scavenge pump drive to my NOS 964 camshaft. I like the 964 camshafts with my K27/7200. I had thought I might need a bigger turbo but it's a good match imho.
Running great finally. ![]()
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
I'm also using one of the Pulsar turbos (also recommended to my by kamaro). It's the GT3582R - I've got about 3k miles on mine and so far no issues.
Chain fence eating turbo
My 60-1 drained to the chain housing and worked ok and then I drained my BW S366 to the oil drain plug. Neither ideal. Bit I never had a problem where oil was blowing past the cold side under high RPM and boost so there's that.
Motor will be 3.0 with 9.5:1 compression. For those that are using the Pulsar turbo, what are you doing with the water cooling connection?
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP Last edited by mikedsilva; 01-24-2022 at 12:24 PM.. |
