T77911S's Avatar
installing cam sync
about to install the cam sync on the smog/scavenge pump housing.
do I need to set the engine to TDC or a few degrees BTDC
I need to use a bolt and nut on the pulley gear correct.
what is the gap
also, I have 2 knock sensors installed on #2 and 5 heads under the fan shroud.
any ideas for perhaps mounting a connector on top of the fan shroud or how to get the wiring in there
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-17-2020, 07:18 AM
T77911S's Avatar
This is my head temp sensor and wire exiting on the right
Knock sensor is on 2 and 5
RACE CAR:: sold
Old 09-17-2020, 07:24 AM
T77911S's Avatar
ms3 evo.
I think I found it.
at least 3 teeth BTDC.
RACE CAR:: sold
Old 09-17-2020, 08:02 AM
Dr J's Avatar
I made a hole big enough for the wiring plug and put a big grommet on the shroud. Then I got a smaller grommet which I cut in one side so that I could put the wire through it, and pushed the second grommet with wire into the large grommet.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 09-17-2020, 02:40 PM
Knock sensor install question? Did you just drill the heads and use a stud and nut to fasten the knock sensor? I need to do this to my heads before installing them.
Old 12-18-2020, 10:36 AM
Turbofrog
smurfbus's Avatar
Ups, my cache showed this one as new post, but anyway:
For Cam sync I used this advice:
The exact cam sensor position is not critical, but it needs to happen before the missing tooth that happens before TDC#1 firing.
i.e. if your engine can be rotated backwards, set it to TDC#1 firing, then turn backwards until the missing tooth aligns with the sensor, then turn backwards another 30 deg or so then set the cam sensor to line up with the tooth.
So my cherry hall sensor is at the pump gear FW side a bit above where TDC was. IIRC about 1mm gap, no misses sofar.
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 07-21-2021, 10:50 PM
T77911S's Avatar
for the temp sensor and Knock sensor I had the heads drilled and threaded.
one knock on each side.
RACE CAR:: sold
Old 07-22-2021, 08:13 AM
