Cam/Crank setup - trigger offset?
Hello all mate
I'm working with a Honda V6 with an infinity 6 ecu motor 3.7L There is a camshaft sensor only, no knees 46 teeth on the pulley and the number of teeth between the top dead center to the teeth of the distribution sensor 9 teeth Tell me how can I set it up? at what degree should the ignition angle be set? The order of the bobbins of coils 142536 There is no sensor on the crankshaft and no missing teeth ========================================== The spark and impulses on the nozzles are obtained only when choosing this very first one in the tuning program but won't start ================================================== ==== AEM EPM Crank(+): Digital 0, Hall Effect Crank Edge: Falling Crank Noise Cancellation: 10 (Adjustable in Advanced Setup) Crank Teeth Count (per rev): 12 Cam1(+): Digital 1, Hall Effect Cam Edge: Falling Cam Noise Cancellation: 10 (Adjustable in Advanced Setup) Cam Teeth Count (per cycle): 1 Cam Sync Adjustment: 0 Trig Offset [degBTDC]: 0 Pickup Sensor Delay [us]: 100 Please help.Thanks Best Regards Tair Last edited by Tair; 04-07-2021 at 12:16 AM.. |
Hi -- you will get much more help with this on the archived AEM Infinity forums
https://web.archive.org/web/20200920022459/http://aemelectronics.com/forum
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
