Cam/Crank setup - trigger offset?
Hello all mate
I'm working with a Honda V6 with an infinity 6 ecu motor 3.7L
There is a camshaft sensor only, no knees
46 teeth on the pulley and the number of teeth between the top dead center to the teeth of the distribution sensor 9 teeth
Tell me how can I set it up? at what degree should the ignition angle be set?
The order of the bobbins of coils 142536
There is no sensor on the crankshaft and no missing teeth
The spark and impulses on the nozzles are obtained only when choosing this very first one in the tuning program
but won't start
AEM EPM
Crank(+): Digital 0, Hall Effect
Crank Edge: Falling
Crank Noise Cancellation: 10 (Adjustable in Advanced Setup)
Crank Teeth Count (per rev): 12
Cam1(+): Digital 1, Hall Effect
Cam Edge: Falling
Cam Noise Cancellation: 10 (Adjustable in Advanced Setup)
Cam Teeth Count (per cycle): 1
Cam Sync Adjustment: 0
Trig Offset [degBTDC]: 0
Pickup Sensor Delay [us]: 100
Please help.Thanks
Best Regards Tair
Old 04-06-2021, 11:10 PM
TurboKraft's Avatar
Hi -- you will get much more help with this on the archived AEM Infinity forums
https://web.archive.org/web/20200920022459/http://aemelectronics.com/forum
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 04-07-2021, 09:31 AM
