-   -   Building a 3.2 short stroke (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1159964-building-3-2-short-stroke.html)
gsmith660 03-27-2025 04:18 PM
The plan is to use the 915 while we shop for a G50 01 to swap out I am going to run the engine detuned until the swap then unleash the beast
quattrorunner 03-27-2025 04:34 PM
It'll be great with .7bar.
gsmith660 03-28-2025 12:52 PM
.7 bar is where I was going
gsmith660 03-29-2025 05:26 PM
http://forums.pelicanparts.com/uploa...1743297951.jpg
New steering wheel
Kiddwayaa 03-30-2025 12:23 AM
Cool motor build,, Gonna work on these small projects until I get the motor back.
gsmith660 04-02-2025 10:06 AM
http://forums.pelicanparts.com/uploa...1743617056.jpg
Assembly has begun first half head studs installed and stress checked working on the other half.
gsmith660 04-03-2025 01:39 PM
http://forums.pelicanparts.com/uploa...1743716223.jpg
http://forums.pelicanparts.com/uploa...1743716236.jpg
http://forums.pelicanparts.com/uploa...1743716252.jpg
http://forums.pelicanparts.com/uploa...1743716267.jpg
http://forums.pelicanparts.com/uploa...1743716284.jpg
Major progress! Turbo repaired and on the way back to me
gsmith660 04-10-2025 07:54 AM
http://forums.pelicanparts.com/uploa...1744300388.jpg
http://forums.pelicanparts.com/uploa...1744300403.jpg
More goodies today thanks to Chris at turbokraft for the quick turnaround
gsmith660 04-10-2025 02:24 PM
Not the prettiest weld but it will holdhttp://forums.pelicanparts.com/uploa...1744323883.jpg
gsmith660 04-10-2025 05:39 PM
http://forums.pelicanparts.com/uploa...1744335503.jpg
New 60 lb injectors Siemens deka
gsmith660 04-15-2025 05:39 PM
http://forums.pelicanparts.com/uploa...1744767395.jpg
http://forums.pelicanparts.com/uploa...1744767409.jpg
http://forums.pelicanparts.com/uploa...1744767422.jpg
http://forums.pelicanparts.com/uploa...1744767444.jpg
http://forums.pelicanparts.com/uploa...1744767459.jpg
http://forums.pelicanparts.com/uploa...1744767473.jpg
http://forums.pelicanparts.com/uploa...1744767492.jpg
http://forums.pelicanparts.com/uploa...1744767506.jpg
More assembly pics we have a short block!
gsmith660 04-15-2025 06:03 PM
Cylinder heads by the end of the week real close to having a long block. Getting excited!
gsmith660 04-15-2025 06:05 PM
3.5 lbs of rotational load so the case and crank is straight.
gsmith660 04-19-2025 09:34 AM
Heads are done picking them up Monday P/Cs installed getting ready do volumetrics and set compression ratios. Cams and rockers will be done by Friday and on the way back to us. It’s getting done!
gsxrken 04-19-2025 02:44 PM
Good progress. Nice milestone to get that case buttoned up. What sealant did you use?
gsmith660 04-21-2025 01:13 PM
http://forums.pelicanparts.com/uploa...1745269956.jpg
http://forums.pelicanparts.com/uploa...1745269970.jpg
http://forums.pelicanparts.com/uploa...1745269986.jpg
The heads are done!
gsmith660 04-21-2025 03:22 PM
http://forums.pelicanparts.com/uploa...1745277668.jpg
Measuring deck height and volumetric measurements calculate C/R
Veeveessees 04-23-2025 01:56 PM
sweet.
gsmith660 05-07-2025 02:51 PM
http://forums.pelicanparts.com/uploa...1746658158.jpg
Love Gibbs oil cleaned up my intake the parts washer fluid started some sort of corrosion that I couldn’t get to stop until I put Gibbs on it.
gsmith660 05-08-2025 06:48 AM
http://forums.pelicanparts.com/uploa...1746715671.jpg
New injectors installed
