The market's gone wild! Stuff's either super hard to find or the prices are out of this world. Take the 3.2s, for example. You used to be able to pick one up for like $6,500, but now they're starting at $15K and up, and that's just for one that might need some TLC. And don't even get me started on rebuilt 3.3s - $35K is steep, but I guess it's a relative bargain if the rebuild's done properly.
Well I am really disappointed I bought an ignition switch 3 years ago genuine Porsche part and now I am haveing issue with it not making contact in the run position
Nice progress. When you slide the cams in they spin freely, otherwise you’ll need to try retorquing the cam tower fasteners in random sequences until the cams don’t bind. Ideally this is done before the anaerobic sealant sets up, but you’ll probably be fine
http://forums.pelicanparts.com/uploa...1746906592.jpg
Alternator and cooling fan cleaned up and ready to be installed |
http://forums.pelicanparts.com/uploa...1747164351.jpg
http://forums.pelicanparts.com/uploa...1747164379.jpg http://forums.pelicanparts.com/uploa...1747164399.jpg Getting down to where he is just waiting on parts to be shipped back to him. Nice to see that sump plate actually on the engine it’s been sitting on my shelf forever seems like. |
Took Chris at turbokraft suggestion an deleted the fuel accumulator http://forums.pelicanparts.com/uploa...1747444731.jpg
For a turbo 3.2SS, what oil pump does the brain trust recommend?
Just got notified that the cams are done and he got in a shipment of rocker arm bushings so he will finish up the work on my parts this week and they will ship out Tuesday
Today I worked on repairing the satellite antenna on the Porsche and tested it I will leave the receiver installed in the 911 since I have Sirius in the new car until the end of Aug
Waiting on parts. The story of my life.
Final build specifics:
79 3 liter engine cleaned and refurbished Crank magnafluxed balanced and polished std/std Pauter rods ARP con rod bolts Camshafts and rocker arms refurbished and new grind specific to this build by Dockerty Mahle Motorsport 930 3.2 pistons and cylinders 7.5 to 1 C/R Coated bearings and gasket set from EBS GT 3 oil pump piston squirters reamed out 10 thousands of an inch Upgraded oil bypass pistons ARP head studs and through bolts New pressure fed tensioners Refurbished heads twin plugged New Siemens deka 60 lb injectors All the engine tins powder coated Modified scavenger system to pump back to crankcase vent Installed new 1/2 inch fuel lines stainless steel Turbo sent back to Turbokraft and upgraded with billet wheels to support more horsepower Installed strut tower bracing in preparation for coilover suspension New Sachs power clutch tower support the expected horsepower increase What do you all think? |
Say goodbye to second gear.
LMAO....Facts.
LOL I’m sure that’s why the search for a G50/01 is in progress to shoehorn in
http://forums.pelicanparts.com/uploa...1749508585.jpg
http://forums.pelicanparts.com/uploa...1749508585.jpg Powder coat stuff back an update on the cams and rockers is that they are next in the queue. |
Fun build here for sure. Enjoying this thread very much. Patrick
http://forums.pelicanparts.com/uploa...1750524093.jpg
http://forums.pelicanparts.com/uploa...1750524110.jpg http://forums.pelicanparts.com/uploa...1750524148.jpg http://forums.pelicanparts.com/uploa...1750524165.jpg http://forums.pelicanparts.com/uploa...1750524188.jpg Last parts are in and final assembly has begun the talk is that I will have a complete long block in my shop next week |
http://forums.pelicanparts.com/uploa...1750524434.jpg
Another reason I hope I never come face to face with that ******* that sold me the engine so much was misrepresented |
