JoeMag's Avatar
Twin plugging with 964 twin dizzy?
Guys -- Has anyone here done this on 930 in their efi conversion? What is involved? At first blush seems like a much easier (and maybe less costly?) conversion than multi coils w/trigger wheel on crank.
--Joe
Old 11-17-2006, 10:36 AM
Joe,
There are pros and cons to doing this, which I'll let others hash out. But it can be done with a twin distributor (which used to be debated). Here's a thread where I posted a pic of an EFI 930 with a 964 distributor.
Pelican thread
Rob
Old 11-17-2006, 10:59 AM
JoeMag's Avatar
Rob -- thx. ...that an old post so I'm hope'n some folks can give details of how done.
YermanCars -- I just was reading another post and see you're going to do this. What's required?
Old 11-17-2006, 11:39 AM
saw that to. Also saw his for sale thread. I wonder if he is supercharging it or something as he was talking about DE's etc.. Anyhow on topic I think the EDIS is the way to go its pretty cheap if you already have EFI . if not go the dizzy route
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 11-17-2006, 12:23 PM
JoeMag's Avatar
EDIS?,,... don't recognize that.
Old 11-17-2006, 01:54 PM
Send a message via Yahoo to Lukesportsman
Crank fired (timed to cam, obviously) distributorless ignition with typically multiple coil packs. Think new car applications applied to our older cars.
Many are using the Ford packs, which I also plan to do. There are some articles here and elsewhere...usually in reference to TECII or MegaSquirt type EFI's though obviously others apply.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 11-17-2006, 02:51 PM
A930Rocket's Avatar
If you use a 964 dizzy, don't you have to change the gear drive on the crank?
Old 11-17-2006, 03:32 PM
Like 930Rocket suggests, don't SC and 930 engines require a reverse rotation dizzy or gear swap?
Luke S.
Old 11-18-2006, 04:26 AM
I have not done it yet, but I will over the winter. The reason I am doing it is because I purchase a SDS efi system that uses the distributor for ignition, not coils. I was force to this path because of it. I will be running 2 ignition boxes, 2 coils and the 964 twin dizzy. I believe on a 3.2, I don't need to change the gear, but on the SC and 930's you do.
Williamknightperformance.com
Perfectpower.com
Old 11-21-2006, 06:00 AM
I would never supercharge my Porsche. I am maybe looking to change my setup around a little.
Perfectpower.com
Old 11-21-2006, 06:02 AM
glad to hear. Can't wait to see the next setup.. good luck
Ben
89 944,85.5 944
914-6werkshop.com
Old 11-21-2006, 06:19 AM
964 distributor will require a 3.6 dizzy drive gear on the crank. Contact Steve Weiner at Rennsport Systems for more info.
Old 11-28-2006, 01:00 PM
WydRyd's Avatar
That's for the 930 and SC's right? For the 3.2 Carrera, it's simply a drop in affair?
Can someone plz verify?
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 11-30-2006, 04:03 PM
Yes, The twin dizzy is a plug and play w/ the 3.2.....
Perfectpower.com
Old 11-30-2006, 04:25 PM
