Air Medal or two
afterburn 549's Avatar
need a cheap way to retard timing
is there a cheap box that will retard timing when things start to come on to boost ?? this is on a dizzy, cis sys. 2.7 just so everyone can say.........she's gonna blow !!
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 11-17-2006, 07:52 PM
BoxxerSix's Avatar
Cheap, not that I'm aware of. MSD produces what's called a BTM or Boost Timing Master ignition module that can retart timing up to 15 degrees in 1-3 degree-per-psi increments but it may need to be modified to work with a dizzy. It is an ignition module in itself(amplifier) and works well with single coil ignitions but I've never personally put one to use on a porsche engine. I did have one equipped on a different turbocharged vehicle I owned in the past and it worked very well.
Regards,
Adam Hennessy
Old 11-17-2006, 08:17 PM
iamchappy's Avatar
I am running a MSD BTM on my turbo 3.12 engine it receives the boost pressure from a vacuum line running off of the throttle body, works very well. I have twin plug and have both Blaster coils running pigtailed from the MSD per Henry at Supertec's recomendation. There are some that disagree with this setup but Supertech's never had a problem with it.
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 11-17-2006, 08:34 PM
Crotchety Old Bastard
RarlyL8's Avatar
You don't necessarily have to retard your timing on boost. The early 930s did not have a timing retard function, full advance was set at 28*. Your timing curve will depend on how much boost you run, what your C/R is, fuel octane, and single vs twin plug.
I assume you have standard low C/R 2.7L with single plug and pump gas with maybe 0.5bar boost. Should not need to retard on boost, just tune it well.
Old 11-17-2006, 08:49 PM
BoxxerSix's Avatar
The only thing I've ever heard about using the BTM with dual coils is overloading the driver circuit if the impedence of both coils is too much for it. If Henry says it works and it is in fact working for you then that's good news because I could really use it for a future 3.6 project.
Which Blaster coils are you running(part numbers) and could you possibly run a primary/secondary ohm reading on the coils for me? It would help me out alot in setting up something like thi in the near future
Adam Hennessy
Old 11-17-2006, 09:17 PM
930turbo's Avatar
Here's another cheater short cut for single MSD & twin plugged applications. Go to your local high performance motorcycle shop and purchase an aftermarket coil for just about any in-line four super bike. They use twin-lead coils fired by a single signal input.
'77 930 turbo Garretson I/C 1 BAR spring, (2) '82 Triumph Bonneville Royal Wedding Edition
Past rides: '74 914 1.9 liter twin plugged track car, '83 928S, '87 924S, '75 911S w '78 ROW 3.0, '72 911T, '70 911T and various other insignificant domestic examples. Happiness is a grey tailpipe! Turbo lag......it's worth the wait!
Old 11-18-2006, 05:45 AM
BoxxerSix's Avatar
Actually cheaper and easier to buy for v-twin applications. Referred to as dual fire coils. Nology, Dyna, Compufire, Crane....just about all the big name companies make one or more models to suit. Used in waste spark applications on V-twin. Good idea though for a crank trigger setup.
And if someone wants to try the above avenue of "twin pluggin", go with Compufire as they just produced a low ohm dual fire coil that works great with DIS ignition modules.
Adam Hennessy
Old 11-18-2006, 01:30 PM
Air Medal or two
good onfo here as per usual Thanx !!
Old 11-18-2006, 02:30 PM
7.0:1 > 11.3:1 > 7.0:1
How much is a 930 USA distributer compared to these electronic options? I realize it won't provide adjustability, but it's bolt in and will give you boost retard.
Old 11-19-2006, 08:09 AM
Air Medal or two
Hmm..... that might be a real good idea...got one ??
Old 11-19-2006, 08:12 AM
You might be able to pick up an old Electromotive setup, like the TEC-1, and use just the ignition side of it (not the fuel side). I did that on a previous iteration of my 930 and got twin ignition and a fully programmable timing "curve" that used a MAP sensor for boost retard. A complete setup can probably be had for less than $1K.
Old 11-19-2006, 12:00 PM
Sold mine to gpc turbo. You might check with him or throw up a wanted ad. Should be a good handfull of them sitting around.
Jim
Old 11-19-2006, 01:09 PM
A930Rocket's Avatar
Will the Electromotive XDi ignition system work? It's about $1175 for single plug version.
Old 11-19-2006, 05:50 PM
Air Medal or two
holy smokes batman I mean cheap, cheaper ,cheapest, and lots less then that ....some one some where has got to have an old 930 dizzy under their bench taking up way to much space.......................If I throw a grand at it for a stand alone I might as well throw two more and get it over with and have injection too!!
Old 11-19-2006, 06:55 PM
A930Rocket's Avatar
When you're talking Porsche, this is CHEAP! Sounds like you're talking FREE!
Old 11-20-2006, 10:23 AM
Air Medal or two
one can always hope........................
Old 11-20-2006, 05:38 PM
RarlyL8's Avatar
930 distributors "generally" go for $200-$300 depending on year and condition. If you do a search you will see a few have sold here on the board.
Old 11-20-2006, 07:27 PM
Air Medal or two
I guess I am whacked ?? If I were taking this proj serious I would go with a complete stand alone sys. In my brain I see these dizzy(s) as "antiques" and who could want one ? cept for me of course in my blow it to Shynoah configuration...............
Old 11-20-2006, 07:39 PM
