Need reference for carpet
Wow, I got wrapped up and spent the last 2 hours reading "Dead man walking" thread Dead man walking... and almost forgot what I came here for...
I'm installing new carpet in my 930 and I'm putting quite a bit of effort into the prep work. Removed everything that can be removed from the cabin and cleaning it up and getting prepped for install. I picked up some lightweight carpet material from Pep Boys the other day and while it is easy to work with, I am getting concerned about its durability. Given the amount of work that I am putting into this, I don't want to install some crap carpet that will self destruct in 6 months. Has anyone replaced their carpet (themselves) and if so, what kind of carpet did you use and where did you get it? Any ideas or suggestions will be appreciated. TIA
1988 - 930 Porsche (track Car) 2002 - Panoz (track car) 2002 - 996 Porsche (weekends) 2006 - M5 BMW - (daily Driver) 2006 - F250 turbo diesel |
Well I tried to do it my self and gave up. I bought the best german carpet set made 27 pieces ! I could not do it so I will bring it to a pro. I am pretty handy even put in my own headliner so to give up means to make it look great is near impossible in my book , I also have a roll cage and no rear seats. Good luck. I would also make sure your children , wife and dog are not around to bother you.
1986 blk 930 2000 expedition 2000 bmw 3 series convertable 1996 Silverton 312 sedan bridge |
Here are the humble results. Not what you would expect from a factory install, but not that bad either... ![]() I will now attempt to do the same with this....
Is that NOS in the trunk? If so, how is that working for you?
1987 930 1956 Chevy 3100 2009 Subaru Forester 2003 KX250 X2(I like my toys!!) |
I usually don't even have the tank in the car anymore but I put it in for this picture.
Very sexy, I like it. so do you have it so it shuts off under boost or WOT above a certain RPM?
Sounds like an interesting experiment.
Wow! This is your trunk? I wish mine looked that good.
Zombie
No carpet but took hours!!!!!!!!!!
BTW you want to use GERMAN SILVER KNIT in a turbo it cost twice as much as domestic pile. If you want to maintain your turbos plush carpet.
The Pragmatist Last edited by tonypeoni; 12-30-2006 at 04:44 PM.. |
Looks good Tonypeoni... having tackled the project I can appriciate the work involved in your project.
OK, back to my grizzled 930... I got most of the old carpet out. Took the roll bar out so that I could get better access to the back seat. After tearing out the old carpet in the back, I found this... It's a molded insulated insert that Porsche put over the metal body to create the "back seats". Can anyone think of any reason that I shouldn't just tear all of this crap out and glue my carpet directly onto the body of the car? I'm assuming that the noise level will increase but that's not really an issue with me. Any suggestions?
Never mind, I decided to tear it all out. Don't need the extra weight anyway. hehe, made the mistake of showing my wife.
She's freeking out. I keep telling her that it's gonna be OK but she has her doubts. Guess it's to late to turn back now...
OK, it took a little longer than I expected. But what project doesn't?
That's fabulous work. Interesting that you have carpet everywhere in the car. Mine only has the mats as carpet.. and then some around the center console.
Great job Squerly.
hey whats the small red button and red light on your center console? I only ask because I just removed my console as part of a recarpet job, have what looks like the same two items but don't know what they heck they ever did.
nice work by the way on the carpet. What did you use to pull the molded stuff out?
Rob Montgomery '88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running |
I have no way to know for sure, but I think that I dropped pretty close to 10-15 lbs. by removing the factory carpet and the molded rear seats. The stuff I put back in was very lightweight and couldn't weigh but a pound. The 1/2 gallon of contact cement was the heaviest thing that went back into the job. Just a heads-up in case you don't already know, but there is a main feed from the battery that is routed right behind this wall. I drilled a hole through the wall and drilled right into it. The drill bit hit the power cable and all hell broke loose. I immediately jerked the drill out but in my haste I broke the bit, leaving half of my bit stuck into the live hot wire. The rest of the bit of course was grounding out against the metal of the car. Smoke and sparks going everywhere! Made for an interesting 30 seconds. At first I had no idea what I had hit and it was impossible to see anything from underneath the car. I wound up chiseling a 6" X 6" hole through the metal wall to find out what had happened. Anyway, keep it in mind if you decide to mount anything against that wall.
OK, the seats are in, the molding is on and this project is a done deal. btw, the seats aren't really purple, the flash just made them look like that for some reason.
Squerly -
Great job! Did you do the door pockets as well? I heard they are a bear to rip off the old stuff. Also, what company/source did you finally use? I liked that your set had full carpet on the floor pans, where most just use mats. Very clean look. Thanks, Glenn
Glenn 87' 930TT |
And by company/source I guess you mean where did I buy the carpet? I used "Pep Boys". Hehe... I bought 4 rolls of lightweight carpet material from them and cut the pieces myself.
Hi Squerly,
I like your ingenuity. I've seen carpet material I liked some place and had the same thought. Just never had the balls I guess, but you may be the inspiration necessary. Clever technique to get the residue off the door panels! Good to know. Thanks a lot. Your car looks great! Glenn
Glenn 87' 930TT |
Hey Jim,
That looks great! Way to go man! Maybe I ought get you to come and be our carpet man.
Thanks! Don Ramsay E Mail: aircooledclassicsporsche@gmail.com The father of 964 Backdating! www.aircooledclassics.co www.facebook.com/AirCooledClassicsPorsche/ www.instagram.com/aircooledclassicsporsche/ |
