Me like track days
Synthetic Oil......opinions and testing
Open discussion, thought I'd toss out a few data points as our 930s are very tough on oil....
Friend is a chemical engineer and does not appreciate the Mobil 1 PR machine. Feels that Redline is the best synthetic oil available: > redline is expensive and you get what you pay for. > > if you look at the HTHS specs (high temperature, high shear) > nothing compares to redline. this is the best indicator of how > well an oil can stand up to a high revving turbo engine. > > if you look at the flash point, the redline is also higher > than just about everything else.. this is the temperature > where the oil vaporizes. > > mobil 1's numbers are going downhill and people have > discovered (from the material data safety sheet) that > they have started to put in cheaper dino based ingredients > compared to what their original formula was.. this is > not information that marketeers can spin.. they have to > say what the oil comprises of. > > there was a huge controversy at the oil geek web site > over mobil 1.. and mobil has been very evasive > to inquiries. > > also, people have sent used mobil 1 for analysis and > have found that they don't hold up as well either. > the M1 0W-40 is pretty bad, it degrades after just > 5000 miles to a 0W-30 and will no longer be > adequate for a turbo engine. > > let me know if you need more info...
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
*****, that's scarey stuff! I've been using the M1 5W-50 oil in my car. Any thoughts/feedback on that oil?
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
royal purple is pretty good think
Craig,, good to know, just curious who makes Redline?? and how many miles do most of you go between oil changes ?? ( assuming a track day or two in there??)
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
Ok, how many people are gonna leave their oil in the car for 5000 miles anyway???
I do good if my oil stays in the car for 800 miles, much less 5000.... But I've stuck with Kendall....
Brian Keith Smith |
Forced Induction Junkie
I think Castrol has really stepped to the plate on their Syntec Synthetic and synthetic blends. I used both in my in 930 and Audi Quattro and they have held up remarkably well. Change the oil in the Audi every 2 months and the 930 twice a year.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
Mobil 1 doesn't use PAO as a base for it's synthetic oil in USA, as far as I know. I guess that doesn't make it a synthetic oil anymore.
Anyway, todays oils are much better than oils that were around when theese cars were sold anyway. I have good expirience with Shell Helix.
Thank you for your time, |
Motul 300V all the way
Me like track days
Brian, I agree the 5,000 mile thing doesn't - and shouldn't apply to us.
I'd still venture to go on a limb and say that Mobil 1 is probably a better choice than a pure natural oil for a 930 that sees hard use. But there appear to be beter choices in synthetics This is a bit telling, however: > mobil 1's numbers are going downhill and people have > discovered (from the material data safety sheet) that > they have started to put in cheaper dino based ingredients > compared to what their original formula was.. this is > not information that marketeers can spin.. they have to > say what the oil comprises of. Along with: > if you look at the HTHS specs (high temperature, high shear) > nothing compares to redline. this is the best indicator of how > well an oil can stand up to a high revving turbo engine. > > if you look at the flash point, the redline is also higher > than just about everything else.. this is the temperature > where the oil vaporizes.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno Last edited by Craig 930 RS; 01-15-2007 at 11:47 AM.. |
Me like track days
Want all the oil reading you can handle?
Check it out - these guys are way into it and appear to know their *****: http://www.bobistheoilguy.com/
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno Last edited by Craig 930 RS; 01-15-2007 at 11:45 AM.. |
Me like track days
No doubt. Next thing ya know we'll have lengthy discussions about an intercooler or something.
Me like track days
Reply from Mobil 1 states they do use the PAO as a base (?)
(I'm not that knowledgeable about the in-depth tech oil stuff.) The people on the oilguys site are a typical group of internet chatters...kinda like another site we know. There are a few great ones on there - just takes time.... Me personally? Mobil 1 is fine as far as I can tell. I change it quite often due to frequent track use AND due to the fact that I can only get about 1/2 the oil out per oil change. Lots remains in the 3 oil coolers and lines. Plus I have a chitload of previously purchased M1 in the shop
craig,
I hope you realize I was not slamming you or this forum....it is the bobistheoilguy.com oil forum I ws laughing at.
switched from Mobile One to Royal Purple XPR 20/50, saw a real world 12 to 15 degree decrease in oil temperature
___________________ Ryan 2001 996 Twin Turbo 1982 930 |
Me like track days
How would that be possible?
my only guess is that it absorbs heat better and moves it through the coolers quicker. I am running about 15 quarts, 5 of which is still mobile one 5w50. Will be diluted even more when I change oil next week. Running 3 coolers 1 B&B in front, 44Row Mocal in wheel well (two 6 inch fans) and stock engine cooler.
Craig, just read your spec sheet. We have the same basic set-up. 3.4, K27, 7.5:1 compresson, 964 cams, B&B Headers. My heads were custom ported (will look up the cut tonight), I have a Koklen intercooler and Monty muffler - no cat
Me like track days
(Self-hijack)
Cool. Link me to your HP/TQ, I think you posted it somewhere...
resident samsquamch
Using Shell Rotella "T" 15W-40 with excellent results in mine. I change my oil VERY frequently! Planning to try Mobil Delvac 1300 Super 15W-40 on my next oil change, this weekend.
edit: ooops, I see you meant for the synthetic oil users to respond. Sorry!
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
