MY 3.8 twin turbo build up. How much HP do you think?
Its a 3.8 built with Carrillo rods, EVO cams ported heads. Twin Garrett GT35r ball bearing turbos. Motec engine management. I wonder how much HP it will make?
Old 03-27-2007, 09:20 PM
WydRyd's Avatar
VERY nice! Depends on how much boost you intend to run?!?
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 03-27-2007, 09:29 PM
I will add more pics as we progress on. [img]
My friend helping to assemble the turbos.
http://forums.pelicanparts.com/uploads10/DSC02326b1175057600.jpg[/img]
Old 03-27-2007, 09:54 PM
what a dork. 1.2 bar. with t3/t4 60s it made almost 700 hp at 1 bar before.the rebuild. On stock internals. I am also running 2.5 intake pipe.
Old 03-27-2007, 09:57 PM
Here is the video.of the car when my friend Alex owned it.
http://media.putfile.com/Alexanders-Protomotive-993-4liter-101147MPH
Old 03-27-2007, 10:05 PM
89turbocabmike's Avatar
Well it should breath alright, but the real question is what size injectors you plan on using
Old 03-27-2007, 10:12 PM
WydRyd's Avatar
Yeh, I would have said mid->high 700's
Merv
'89 911 Turbo Cab
Me like track days
Craig 930 RS's Avatar
A LOT
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 03-28-2007, 08:52 AM
cgmeredithjr's Avatar
I would think that beast should make closer to 1000...especially with individual throttle bodies! Enough turbo to support 1200HP, then consider 8.5hp/lb/min of air flow for the air-cooled 2 valve motor and you get~1020HP...if you can put enough boost to it.
Cleve
Old 03-28-2007, 08:56 AM
Banned
800+ HP., I have a similar setup, but without the tb's, and 3076's instead of 3582's turbos, it is making 807hp at the wheels at 1.45bar, with a good tune yours should make 900+ at similar boost levels.,keep us posted.,Candy.
Old 03-28-2007, 02:23 PM
Delicious motor!....BTW we have the same glasses........................................... .......................and tattoo!
Yasin
Old 03-28-2007, 08:12 PM
WydRyd's Avatar
I think you'll have WAY TOO MUCH HP... so I think you should give me some
Merv
'89 911 Turbo Cab
Old 03-28-2007, 08:53 PM
930gt-40r's Avatar
Bad@$$! Did you bore the case for the 3.8 cylinders or did you use slip ins? You could run that thing on low boost and eat Ferraris and crap Corvettes
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 03-28-2007, 09:30 PM
WydRyd's Avatar
Have you flame ringed the heads/liners for the extreme boost levels you plan to run?
Merv
'89 911 Turbo Cab
Old 03-28-2007, 10:11 PM
beepbeep's Avatar
Cool engine!
Suggestion: check head temps while on-dyno. It will probably deliver ungoodly amount of power in short bursts but I suggest monitoring head temps and tuning the motor so they never exceed 210 deg. C (if you used N/A heads) or 230 deg C (if you used Turbo heads). After that, heads go soft/plastic and all kind of bad things start to happend.
Thank you for your time,
Old 03-29-2007, 01:13 AM
NICE. 829HP what do I win?
Lincoln Phillip
87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound.
Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs.
"the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker
Old 03-29-2007, 02:40 PM
SLIP IN MAHLE PISTONS.
Old 03-29-2007, 10:01 PM
Heads are flame ringed.
Old 03-29-2007, 10:04 PM
Thumbs up
I will post dyno results as soon as we dyno it as well as a video.
Old 03-29-2007, 10:06 PM
Banned
By no means go over 1 bar with slip ins!! if you want it to last some.,Candy.
Old 03-30-2007, 06:09 AM
