Look in engine fourm for (74 Project )and you will see more info. about the digital wur in Bryan Beaumont's post
Me like track days
No -
Guessing about the ease of 'programming'. Guessing that 'is it better than other options'. It's all conjecture at this point until we see a live product rather than the current vaporware -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Metal Guru
Negative on the search function. Please post a link to the thread.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
Crotchety Old Bastard
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Me like track days
See, feel, what I meant was USE.
Thread
See if this works. http://fourms.pelicanparts.com/showthread.phpt=2888188/highlite=intercooler=sleeper[/URL]
Me like track days
No workie -
Criag, go to a post on this forum page about "930 without a wing" then go to the second post by 125 Shifter and open the first thread on his post and go to page #2 and post # 25 . This is the only way i can tell you to get there . It is about a digital wur that came from Turbokraft . The same car is on their web site
sudo apt-get purge 930
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey Last edited by equality72521; 11-30-2007 at 06:09 PM.. |
I talked to Neil a few times but needed to get the car running after months of down time. Went with Leask's and it runs great out of the box.
And that guy talking about the digiWUR is from 06...still no real product.
WTB: 964/965 Turbo stuff...carbon fibre bits, Techart wheel parts, RS/lightweight flywheel, 993 EVO uprights, G50 gears or 6 sp., 964 RSR swaybars, custom droplinks and any other cool stuff, pm me! Also a nice medium build 327 Chevy engine. Coming SOME DAY...1991 3.3 turbo, Tahoe Blue Metallic with some mods
With enough patients with Ejunk and my two hands, I could get a system going for two G- just not the blingy shiney one that everyone wants. I had a Cis car and the fuel mileage can made to look good on the highway, but decreases drasticly with any variation like stop and go. And I like to run more than 500 at the crank- (427 C5 vettes don't play with much less). Now I didn't say this is a bad product and I for damn sure wish that it was around when I had CIS, but EFI saved Porsches for me- it was like driving my first Fast Porsche. This product most defenatly has an undeniable market.
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
Accell Dual Sync. Distributer (so cool and so easy) 3.2 plenum Gt-2 cams 96' twin turbo crank (3.6) pauter rods STOCK pistons and cylinders custom 4" intercooler Garret GT-37R dual ball bearing turbo --------For sale Tial 46mm wastegate-----------------------------For sale Modified B&B's--------------------------------------For sale Accufab 75mm throttle body This is my entire setup and the stuff thats not Accel (all hardware) is the reason for going to EFI- with out it, I would not be able to use any of it save for the crank and rods.
I wouldn't bother commenting on something unless I have either seen in use first hand or actually used myself. If you can't tell I have a definite opinoin on this subject and it ain't from readin' second hand info on the internet.
Do you remember the thread several weeks back discussing cams where I posted the findings of a friend who was extensively exploring CIS engine combos? You cannot do that without also extensively exploring the WUR. Along with a half dozen cams and turbos he also tried out various adjustable WURs and a digital WUR. There is nothing difficult about the operation of a digital input WUR. It's simply manipulation of the normal inputs that operate the WUR, fuel pressure, temperature, electricity, vacuum, and boost. It is true that none of that makes any difference, no digi-WURs that I am aware of are currently available for sale. Once they do become available we will see many posting on impressions.
Forced Induction Junkie
There certainly is no conjecture on my part. But.....and it's a big but, we have to get off this wagon of trying to find the Holy Grail of plug-and-play injector controllers. The WUR is nothing more than a mechanical version of an ECU with fewer inputs(vacuum, boost, temperature) compared to an ECU. If you want to tune your digital WUR engine with a wideband Innovate, you can certainly tune an EFI'd engine. As the old programmer's adage goes, "garbarge in, garbage out".
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
Metal Guru
I like the idea of using the 3.2 intake but that throws you into a custom I/C, right? What did you do about the port mismatch between the intake and stock heads (assuming that you started out with stock heads)? So what does your displacement end up being with the 3.6 crank and stock cylinders?
My heads I had welded, machine, and finally ported at Verdan tool. I also had to have them shave a little off the leading edge of my piston ring lands ( I think 1MM). The inter cooler is the last I/C I will ever buy because I have never seen a better one for a Porsche let alone one that fits under a stock wing. I used a 1000 hp Spearco core and had Miller Race Car make the end tanks for it. As for the displacement, I believe that it comes to a little less than 3.4 but it gives her a noticeable kick in the low end.
Metal Guru
Can you post a couple of pictures for us?
Wo ist die Rennstrecke?
For example, yesterday morning was cold, so I decided to go out and set the inlet air temp correction table, since most of my tuning has been in the 70 degree temp range (yesterday was 35). I found that I had to add about 1.5% more fuel to precisely achieve the desired AFR in EVERY throttle position. Now that it's set, I'm done and never have to come back to it. Try that with CIS. About a week ago, I re-set the idle to reflect an AFR of 15 to help keep the plugs clean and idle smoother. The way I did it was adjust timing, idle solenoid position and fuel. Again, not with CIS. And my last and favorite example of the differences is throttle response using fueling tables, ignition tables, accel enrichment tables and even boost tables. Don't look for this flexibility or performance gains on any CIS. But it comes with a cost. I guess my point is that CIS is incredibly competent on its own and does not need to be compared to an EFI conversion - if you do, you are fooling yourself and mis-leading others. Level 1 is CIS up to 400 hp. Level 2 is EFI and is 300hp and more. I think if the digital WUR does surface, and they charge $1000, it'll be under-priced, and worth every dollar (at least with Neil Harvey's unit, which I've never seen). At the very minimum, I had to tune my WUR twice per year (cold and warm weather) and each time it took about half a day to dial it in correctly - and what a pain in the a$$. If it can be done through a laptop, and not have to go to the WUR for each adjustment, that would be great. If you don't want to pay the rumored $1000 for the digital WUR, then learn to adjust it yourself with a fuel pressure gauge and a wide band AFR. Or buy Brian L's unit. CIS is a great system, but you can throw a lot of money at it and never achieve the performance levels an EFI conversion can deliver. Last edited by DonE; 12-02-2007 at 10:10 AM.. |
B.S. . My CSI car will kick your's A$$ !
