Manassas, VA
Turbo owners beware. My 1991 965 was smoking under the left rear fender when I got home. I pulled off the appropriate wheel and found a large puddle of Mobile 1 under the turbo scavenging pump. I wiped off the oil but I could not see the source of the leak. I started the engine and let it get hot, with no leakage. I was beginning to wonder how that was possible until I shut off the engine.
The oil came pouring out from under the oil pipe leading to the turbo scavenging pump. Silly me, there is a vacuum in that line so I was sucking air until I shut down. I had to pull the oil pipe to see the damage. Many years of rubbing on the heat shield had worn a hole in the underside of the copper pipe. This is a $200+ repair and it should have been prevented by moving the pipe gently up off the exhaust pipe heat shield. Please check your cars to see if you have daylight between the oil pipe and the heat shield. Thanks, Mark ![]()
1991 964 Polar Silver Metallic Turbo Coupe |
Thanks for the heads up Mark, I'll have to go take a look at my 1992. I don't think I have the heat shields anymore though...
Bill |
I think I would have had to braze or solder that leak before I came outta pocket for an OE replacement line. As you said, it's not under pressure....
Heck, maybe a rubber hose/sleve and 2 hose clamps would last forever once you bent it up off the heat shield. |
Good post...which is why my car wears this, I made this line at home and for a few other 930 owners as well, parts cost is around $70
![]() Yasin
Ole Skool - wouldn't have it any other way |
Crotchety Old Bastard
I noticed that tight spot when I had my engine out. Bent a relief in the heat shield to get it away from the oil line.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
I went and looked, and since I have the B&B headers with heat, my line has already been changed...
Bill |
930 Rookie
Nice catch. My previous owner just replaced in December but I will take a look at the clearance.
-Matt Current: 1982 Platinum Metallic 930, stock (P-CarOnline.com) / www.Type930.com Former: 1989 Glacier Silver 944 "S3", 1987 Guards Red 924 S Also in the family: 1992 Polar Silver 968 Cab, stock |
Not to hijack, but Yasin, do you have a picture of the AN fitting at the intercooler for the WG line?
Yasin...
+1 on BSiple's comment.. I would also like to see that connection.. can you tell us also what sizes you used and were there any adapters or all metric thread? Did you also do the line that runs around the back of the motor from the oil tank to the pump? I'm currently in the process of cleaning up both pump lines as mentioned as well as lines to the waste gate. Going with braided stainless. P-
RGruppe #180 So many cars.. so little time!! |
Manassas, VA
Yasin,
Your engine is very pretty indeed! Mine is completely stock. I told my wife that I could fire up the torch and apply some silver solder and the pipe would be as good as new. Maybe she saw some of my previous work, but in any case she said "Hey, that looks like a critical part, you need a new one; here is the checkbook." Yahoo! Mark
Me like track days
Yep, the Slow&Rusty wa is the right way to do it -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Regards - Yasin
Yes I do need the sizes so if you get time to check into it I'd appreciate it. I'm in the process of cleaning-up the engine bay, replacing all the old hard & brittle hoses and lines. Have decided to use braided, and it always slows me down when I'm figuring out the size conversions or adapters and fittings! If I can pick someone else's brain that's great.. so thanks in advance! This is one of those typical "while you're end there" deals.. the swap to braided lines and silicone replacements for some was planned.. but the powder coating, swap of IC and polishing of the unit, and general purdy-ing-up of everything is the extra... and probably the fault of you guys here on this board! So there...Thanks, Paul
Yasin im about to have my engine out and would like to do this as well so as paul said if you got time to give us the sizes and maybe where you bought those hoses i would really appreciate it.
JERRY
1992 968 2011 Cayenne 2007 997 Turbo 1991 964 Turbo 2005 955 Cayenne |
OK guys give me a few days. I am actually away from home right now for a few days and will get back with some answers to you on the hoses and respective part numbers.
BTW, you can purchase the Earls hoses and all the fittings from Summit Racing. www.summitracing.com My best - Yasin
Wait a minute Yasin.. Away from home... Carnival already?
RGruppe #180 So many cars.. so little time!! Last edited by onboost; 01-25-2008 at 07:05 AM.. |
LOL...good one and quick draw there McGraw! Carnival in Trinidad in a few weeks...wish I could go! I would be making braided steel lines for you guys in between the Calypso, rum & cokes and all the scanty fun!
Yasin
Hell, I'm even missing out on www.Cavallino.com this year in Palm Beach! ![]() Paul
Thanks for the heads up. I'm going to have to get under there and see if I have this issue....
Bill 997.2 |
lucittm, I already got that problem with my girlfriend.... guess its time for a new one...
Bad@ss find on that pipe though. Yasin has the right idea with the A/N line though- I think the adapter is m10 or M12-1.25/-8 AN. This is cheaper than a new pipe from the Stealership
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
