Internal vs external wastegate... which is better?
In the sloooow process of turboing my 3.2 and am using a standard K27 HF and exteranal WG at .6 bar. However, looking at newer turbos/ systems, internal wastegates seems stardard. Love the external WG for 'cool' factor and sound, but is it 'old' tech? How exactly do you vary the spring rate on the external WG? Is there any advantage? Thanks
'79 930/934 replica 80 RSR-look(Now in Sicily) 914/6 2.7 (Projekt 908/3) 1965 Karman Ghia-Class winner 2007 Carrera Panamericana/Ducati 900ss/GhezziBrian STW D-Zug Produkte/D-Zug.com |
I was always under the impression the external was the norm in these cars.
In order to vary the spring rate, you just buy one at the rate you want and replace the old one. Or you can just buy the lowest rate / cut the old one, and run a boost controller.
John A. 1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.) 05 Boxster S: For the Track. 06 Dodge Ram 2500 Power Wagon: Tow Vehicle |
OOPS, i meant to say, how do you vary the boost pressure on the INTERNAL wastgates.
The external W/G is best for you. |
That is easy, I have done it MANY times...you have to disconnect the rod to the diaphram, cut it and re-thread it, so it opens later -or - install an inline boost controller to fool the wastegate (I have used Manual Boost Controllers, with great results). Yasin
Ole Skool - wouldn't have it any other way |
Thanks guys. I have seen a lot of guys using Internal WG turbos on TT aftermarket systems, but none for the 930. So the only advantage is of an internal WG turbo is the elimination of a dump pipe and more closely tailoring of the wastegate parameters to a particular turbo?
The only advantage to an internal wastegate is that it's cheap, and *maybe* easier to plumb.
But it's undesireable because it causes a lot of flow resistance due to all the post-turbine turbulence. So if you want big power & efficiency, you want an external WG. Ideally you want the WG to dump to atmosphere (which is pretty darn easy to plumb!) but OEMs can't design that way for emissions reasons. For emissions, you'd route the WG outlet it back into the exhaust stream, preferably at least 1+ foot downstream. So there's little controversy; external is better. ...at least that's what the experts tell me...
1995 993 C2, speed yellow. Protomotive Stage 1 twin turbo. JRZs, RS parts, DL1 logger, etc. Last edited by Eric86Red911; 02-13-2008 at 12:46 PM.. |
Internals suck unless you are going to run it on an intended aplication- e.g 16G on mitsubishi etc and even then you get boost creep. If you are modifing boost levels or plumbing or anything like that, I would just stick with external. Some of the performance based internal (integral) gates are ok I guess, but why bother when the money you save on the wastegate is going to be snatched away by the price of the turbo.
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
