Wink Removing Turbo
I love the 911 turbo look (m491) but can't seem to find them for sale. So with the turbo cars coming down in price; possible to remove the turbo kit and set it to the standard Carrera? If so how difficult?
Old 11-25-2009, 09:13 PM
HoyaBear
hoyabear's Avatar
Send a message via Skype™ to hoyabear
1.) For the love of God why?
2.) it would be a major PIA; you'd have to get new headers, plug up a bunch of spots in the oiling system, and probably fuss around with the CIS a bit.
If you don't want to go fast, just don't give it too much gas...
'86 930: 3.4 Andial build, Web GT2 Evo cams, Carrillo rods, ported/polished heads, MSD 6530, B&B headers/exh + intercooler, K27HF, 1 bar spring, Tial wastegate, Andial FE, Lindsey Fuchs. Back in black!!!
Past:997S cab; '88 930; '86 951; C5 Vette; 4th Gen Z28; 3rd Gen Trans Am GTA; '71 Z28
Old 11-25-2009, 09:30 PM
9dreizig's Avatar
Send a message via AIM to 9dreizig
Dude you've come to the wrong corner of Pelican for that kind of question. Nobody here but adrenaline junkies and guys high on the boost pipe
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 11-25-2009, 10:42 PM
Send a message via AIM to Chuck Jones
If you want the "look"...why stop at the M491 when you can save yourself a LOT of time and money (it will cost you a fortune to modify it) by just buying a 930. I have a friend in New York who just bought a M491 turbo look cab for $29K and for that price you could be into a 930 and be on the road kicking back and enjoying boost right off the bat... rather than looking for parts and trying to figure out how to stuff a turbo into it with all the other attendant parts and modifications you'd have to make.
1987 factory Slantnosed 930 Cabriolet/Guard's red
2002 Midnight Blue 996TT X50
1999 Iris Blue 996 (Dash fire burned and totalled 9/07)
Old 11-26-2009, 01:12 AM
Metal Guru
911nut's Avatar
After the turbo is removed from the 3.3 engine, it would have as much performance as a Yugo thanks to the 7/1 compression ratio.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 11-26-2009, 04:23 AM
tj930's Avatar
Had me in stitches!
But sounds like your better options are i) fit a wide-body kit to 3.2 Carrera, or ii) fit Carrera 3.2 engine + 'box into a 930 shell (but you may want to change to coil-overs, too).
Now, if you'd wanted to make some claims about a 'better Coefficient of Drag' and have a narrow-bodied / slope-nosed / RUF-styled 930, I could possibly understand that (without necessarily approving).. But really, what you're proposing sounds like one of those things which can be summed up with:
"Just because you can, doesn't mean that you should."
Old 11-26-2009, 05:46 AM
Happiest when Tinkering
gsmith660's Avatar
Well it would be about 5-7 grand for the motor and 2-3 grand for the tranny plus new hubs and half shafts because the 930 was unique on all that stuff and then alot of work adapting the carrera stuff into the car and the value would go down the tube. If you want the turbo look then look around they are out there although if you get a turbo and still want to do the unthinkable you will have no problem selling the motor/ tranny combo for more than the cost of the motor you are putting in. I added the turbo to my NA motor and there is nothing like the feel of the boost kicking in cant imagine not having that kick in the ass now!
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 11-26-2009, 05:54 AM
Wayah Road Warrior
Shadetree930's Avatar
Easy enough to do.
Simply remove the Turbo script from the tail and replace with Carrera script.
02 996tt White
87 930 GP White (Sold)
87 911 Targa Guards Red(Sold)
Old 11-26-2009, 06:04 AM
Crotchety Old Bastard
RarlyL8's Avatar
The 930 chassis makes a formidable N/A track car when lightened, which is the only reason I can fathom for doing such a thing. Swapping a Carrera drivetrain for the turbo is easy as the M491 option used the turbo suspension with carrera engine and 915 or G50 depending on year.
The most reasonable and inexpensive thing to do is buy a widebody converted Carrera. These are plentiful and $10K cheaper than a 930.
Old 11-26-2009, 06:29 AM
mark houghton's Avatar
"For the love of God why? It would have as much performance as a Yugo".
My advice would be to eat some turkey, drink a few glasses of wine, take nap, and think on it some more.
Happy Turkey Day, you turkeys!!
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 11-26-2009, 07:14 AM
Send a message via AIM to R390 Send a message via MSN to R390
Bud , I dont post up here much but why would you buy a turbo and remove it ? X 2,000,000
god just to do that would just be the same as asking someone how to convert a 911 turbo 5speed into a 3 speed auto ?
Old 11-26-2009, 07:39 PM
9dreizig's Avatar
OR you could just remove a sparkplug wire or two performance would be about the same
"Todd"
Old 11-26-2009, 07:48 PM
RarlyL8's Avatar
I think a direct answer to your question is "no" you cannot make a Carrera engine out of a 930 engine by simply removing the turbo.
The 930 is a true turbo engine, meaning an engine built specifically to be turbocharged. A Carrera engine is EFI with ~10:1 compression while a 930 is CIS with ~7:1 compression.
The 930 transmission is also built specifically to be used with the long legs of a turbocharged engine and would be a miserable experience bolted to a Carrera engine.
The turbocharger is an integral part of a 930 engine and the specific component that creates the power. To remove the turbo from a 930 engine or add a 930 4spd to a Carrera engine would be akin to hobbling a race horse. To do both would be worse than driving a 912 sportomatic.
Old 11-27-2009, 07:23 AM
